[petsc-dev] Moar namespacing
Jed Brown
jedbrown at mcs.anl.gov
Mon Aug 27 17:50:08 CDT 2012
On Mon, Aug 27, 2012 at 5:45 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Does Fortran2008 have Vec Mat etc also as keywords?
No, but maybe in the next release..
> If you are going to change IS -> PetscIS then you should change every
> stinking non-name-spaced thing in PETSc and boy Matt will be happy. Doesn't
> this change require PETSc 4.0? Note we'll also need to rename all current
> names in PETSc that are more than 26 char long since adding PETSc will make
> them too long.
That's one thing C++ did right: allowing longer identifiers.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120827/40cc49a3/attachment.html>
