[petsc-dev] [PATCH 1 of 3] superlu: fix spelling error 3.0 -> 3.1
    Sean Farley
    sean at mcs.anl.gov
    Sun Aug 26 18:14:04 CDT 2012
# HG changeset patch
# User Sean Farley <sean at mcs.anl.gov>
# Date 1346018864 18000
# Node ID 56899038c8e3e8ee070c93767a77632405801842
# Parent  74d6d3408dc97996a15e1a94cf2e2112183ac7f8
diff --git a/config/PETSc/packages/SuperLU_DIST.py b/config/PETSc/packages/SuperLU_DIST.py
--- a/config/PETSc/packages/SuperLU_DIST.py
+++ b/config/PETSc/packages/SuperLU_DIST.py
@@ -5,11 +5,11 @@
     PETSc.package.NewPackage.__init__(self, framework)
     self.download   = ['http://crd-legacy.lbl.gov/~xiaoye/SuperLU/superlu_dist_3.1.tar.gz',
                        'http://ftp.mcs.anl.gov/pub/petsc/externalpackages/superlu_dist_3.1.tar.gz']
     self.functions  = ['set_default_options_dist']
     self.includes   = ['superlu_ddefs.h']
-    self.liblist    = [['libsuperlu_dist_3.0.a']]
+    self.liblist    = [['libsuperlu_dist_3.1.a']]
     self.requires32bitint = 0
     self.complex          = 1
     # SuperLU_Dist does not work with --download-f-blas-lapack with Compaqf90 compiler on windows.
     # However it should work with intel ifort.
     self.worksonWindows   = 1
@@ -26,11 +26,11 @@
   def Install(self):
     import os
     g = open(os.path.join(self.packageDir,'make.inc'),'w')
     g.write('DSuperLUroot = '+self.packageDir+'\n')
-    g.write('DSUPERLULIB  = $(DSuperLUroot)/libsuperlu_dist_3.0.'+self.setCompilers.AR_LIB_SUFFIX+'\n')
+    g.write('DSUPERLULIB  = $(DSuperLUroot)/libsuperlu_dist_3.1.'+self.setCompilers.AR_LIB_SUFFIX+'\n')
     g.write('BLASDEF      = -DUSE_VENDOR_BLAS\n')
     g.write('BLASLIB      = '+self.libraries.toString(self.blasLapack.dlib)+'\n')
     g.write('IMPI         = '+self.headers.toString(self.mpi.include)+'\n')
     g.write('MPILIB       = '+self.libraries.toString(self.mpi.lib)+'\n')
     g.write('PMETISLIB    = '+self.libraries.toString(self.parmetis.lib)+'\n')
