[petsc-dev] Patch review
    Jed Brown
    jedbrown at mcs.anl.gov
    Fri Aug 24 19:34:27 CDT 2012
On Fri, Aug 24, 2012 at 7:16 PM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Sorry, my sloppiness.
> I should examining it before pushing.
> I'll clean it, and will ask Jie to provide regression tests.
Sounds good, thanks.
> Hong
> On Fri, Aug 24, 2012 at 6:44 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Fri, Aug 24, 2012 at 6:38 PM, Jie Chen <jiechen at mcs.anl.gov> wrote:
>>> I am in fact somewhat reluctant to push out everything before it is
>>> formally published and fully tested. The patch consists of more than one
>>> algorithmic developments that may be far away from maturity (but they are
>>> likely to work), though the authors might be the only ones who care about
>>> the new algorithms at this point. Besides, the codes are now full of hacks
>>> and lack documentation. I have no problem reverting petsc to the old
>>> version temporarily, and I promise I will clean everything to meet the
>>> production requirement, although this might not happen in a very short
>>> time. Meanwhile I think it also does not hurt to keep the patch as is, as
>>> the modification is likely to be used by the author circle only.
>> There isn't a problem with experimental code, but if you are going to
>> push experimental code, it should conform to the usual standards. No need
>> to revert the patch unless you've already decided it is a failed experiment.
>> If something is genuinely useful, we certainly like to have it in our bag
>> of tricks immediately. Waiting until a paper is published to put it in the
>> repo just means that it will take longer to find use in real applications.
>> As far as I'm concerned, an ideal scenario is that by the time someone
>> reads the paper, they already have the functionality in a released version
>> of PETSc, thus can experiment on their own problems without even
>> recompiling. (This being the lowest possible effort, it maximizes the
>> chances of finding other applications where the method is useful, thus
>> maximizing citations, in case that is the metric you care about.)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120824/6dd21c31/attachment.html>
