[petsc-dev] Adjacency relations in Sieve and stencils
    Chris Eldred
    chris.eldred at gmail.com
    Thu Aug 23 17:50:49 CDT 2012
For the extended operators, I was going to write:
1) DMComplexGetLabelClosure- returns the points from a transitive
closure with a given value for a given label (this will implement both
star(vertex) \ support(vertex) and closure(cell) \ cone(cell); along
with many other operators)
2) DMComplexGetNeighbors- returns U cone(support()) OR  U
support(cone()) by setting a Boolean flag
These two operators should cover "nearest neighbors" of all types.
On Thu, Aug 23, 2012 at 12:39 PM, Chris Eldred <chris.eldred at gmail.com> wrote:
> Sounds good- I will write the extended topological operators (
> star(vertex) \ support(vertex) ; closure(cell) \ cone(cell) and U
> cone(support(edge)) ) and let you know if I have questions/run into
> issues!
> -Chris
> On Thu, Aug 23, 2012 at 12:22 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Aug 23, 2012 at 12:19 PM, Chris Eldred <chris.eldred at gmail.com>
>> wrote:
>>> I am working with a 2D unstructured mesh using sieve and I wanted to
>>> get some advice on how to determine adjacency relations using the
>>> topological operators provided by Sieve (cone, support, closure,
>>> star). I have figured out the following:
>>> Vertices for a given edge: cone(edge)
>>> Cells for a given edge: support(edge)
>>> Cells for a given vertex: star(vertex) \ support(vertex)
>>> Edges for a given vertex: support(vertex)
>>> Edges for a given cell: cone(cell)
>>> Vertices for a given cell: closure(cell) \ cone(cell)
>>> The set of edges associated with the cells for a given edge: U
>>> cone(support(edge)) - ie the union of the cones of the support of the
>>> edge
>>> Are there other topological operators that more naturally express
>>> these relations (especially the ones involving unions or complements)?
>> The only other builtin operations are meet and join. You are correct that
>> you
>> want to use union there. We could add routines like
>>   DMComplexGetConeUnion(dm, [p], &unionSize, &unionArray);
>> but it was not clear that would do anything other than bloat the interface.
>> I
>> think the best way to procede is to write these convenience routines using
>> the lower level primitives, and move them into PETSc if they turn out to be
>> useful. I can help you write them.
>>    Matt
>>> Chris Eldred
>>> DOE Computational Science Graduate Fellow
>>> Graduate Student, Atmospheric Science, Colorado State University
>>> B.S. Applied Computational Physics, Carnegie Mellon University, 2009
>> What most experimenters take for granted before they begin their experiments
>> is infinitely more interesting than any results to which their experiments
>> lead.
>> -- Norbert Wiener
> Chris Eldred
Chris Eldred
