[petsc-dev] Ghost values in sieve
    Matthew Knepley
    knepley at gmail.com
    Thu Aug 23 14:18:59 CDT 2012
On Thu, Aug 23, 2012 at 2:08 PM, Chris Eldred <chris.eldred at gmail.com>wrote:
> Awesome- that is easy. How do I access that SF?
I destroy it inside DMComplexPreallocateOperator(), but we can preserve it.
   Matt
> On Thu, Aug 23, 2012 at 12:54 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Thu, Aug 23, 2012 at 1:42 PM, Chris Eldred <chris.eldred at gmail.com>
> > wrote:
> >> I need the adjacency relations discussed in my other post- the only
> >> one that is not part of closure(p) U star(p) is: U
> >> cone(support(edge)). Given an edge p, I need all of the edges that
> >> cover the same cell as edge p.
> > Okay, then for parallelism, I think you need nothing more than the SF we
> get
> > from Jacobian preallocation.
> >   Thanks,
> >      Matt
> >> On Thu, Aug 23, 2012 at 12:17 PM, Matthew Knepley <knepley at gmail.com>
> >> wrote:
> >> > On Thu, Aug 23, 2012 at 12:26 PM, Chris Eldred <
> >> > wrote:
> >> >> Yes- I am implementing the TriSK scheme
> >> >> (www.mmm.ucar.edu/people/skamarock/Ringler_et_al_JCP_2009.pdf) on
> >> >> arbitrary Voronoi meshes. In order to do wind/flux reconstruction at
> >> >> the cell edges, it needs to know about the edges of adjacent cells-
> >> >> which are outside of closure(p) U star(p).
> >> > Great! Stuff that cannot be done with that structured crap. However,
> >> > from
> >> > quickly looking at
> >> > the paper, there is nothing beyond the neighbors, so we can reuse the
> >> > code
> >> > from
> >> > Jacobian preallocation. If you could tell me exactly what adjacency
> you
> >> > need, we might be
> >> > able to do it even more simply.
> >> >    Matt
> >> >> On Thu, Aug 23, 2012 at 11:16 AM, Jed Brown <jedbrown at mcs.anl.gov>
> >> >> wrote:
> >> >> > On Thu, Aug 23, 2012 at 12:12 PM, Chris Eldred
> >> >> > wrote:
> >> >> >> Thanks- that helps a lot. If I need stencils that are larger than
> >> >> >> closure(p) U star(p) (for a higher-order finite difference method,
> >> >> >> for
> >> >> >> example), I assume that I need to create my own PetscSF's that
> >> >> >> describe which points need to be ghosted?
> >> >> > Is this still a fully unstructured method? The Sieve formalism
> >> >> > doesn't
> >> >> > give
> >> >> > you a very efficient way to do this for structured or
> semi-structured
> >> >> > grids.
> >> >> > Even so, if wider stencils are to be supported, I think it should
> be
> >> >> > implemented within the library. Doing it outside with the current
> >> >> > infrastructure is going to be quite a rabbit hole.
> >> >> >> Is there some documentation or example code that explains the
> theory
> >> >> >> behind star forests?
> >> >> > Docs for the basic operations:
> >> >> > http://59A2.org/files/StarForest.pdf
> >> >> Chris Eldred
> >> >> DOE Computational Science Graduate Fellow
> >> >> Graduate Student, Atmospheric Science, Colorado State University
> >> >> B.S. Applied Computational Physics, Carnegie Mellon University, 2009
> >> > What most experimenters take for granted before they begin their
> >> > experiments
> >> > is infinitely more interesting than any results to which their
> >> > experiments
> >> > lead.
> >> > -- Norbert Wiener
> >> Chris Eldred
> experiments
> experiments
> > lead.
> > -- Norbert Wiener
> Chris Eldred
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120823/34099db3/attachment.html>
