[petsc-dev] [petsc-maint #129715] __float128 complex
    Jose E. Roman
    jroman at dsic.upv.es
    Thu Aug 23 11:21:57 CDT 2012
El 23/08/2012, a las 18:13, Jed Brown escribió:
> On Thu, Aug 23, 2012 at 11:02 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 22/08/2012, a las 18:52, Jose E. Roman escribió:
> > f2cblaslapack is more or less prepared for this case already (it is not much tested though, we will make some tests for the w* subroutines tomorrow).
> > What is not ready is PETSc itself. Some definitions are missing. For instance, PetscScalar is undefined, so one should add the following to petscmath.h:106:
> > #elif defined(PETSC_USE_REAL___FLOAT128)
> > typedef __complex128 PetscScalar;
> > #define PetscRealPart(a)      crealq(a)
> > #define PetscImaginaryPart(a) cimagq(a)
> > #define PetscAbsScalar(a)     cabsq(a)
> > #define PetscConj(a)          conjq(a)
> > #define PetscSqrtScalar(a)    csqrtq(a)
> > #define PetscPowScalar(a,b)   cpowq(a,b)
> > #define PetscExpScalar(a)     cexpq(a)
> > #define PetscLogScalar(a)     clogq(a)
> > #define PetscSinScalar(a)     csinq(a)
> > #define PetscCosScalar(a)     ccosq(a)
> > Similarly, MPIU_SCALAR should be defined. Maybe other as well.
> > Jose
> I have pushed a change to petsc-dev that allows to configure --with-precision=__float128 --with-scalar-type=complex
> I have tested this with src/ksp/ksp/examples/tutorials/ex12.c with 1 and 2 processes. It seems to work.
> Please review the change, since I had to modify pinit.c
> It looks good to me. Thanks.
> A couple of comments:
> 1) The f2cblaslapack interface to quad precision subroutines (q* and w*) is defined only in the case of "uscore" mangling. Maybe a test in configure should assure this.
> Don't we just need to copy and update the list of defines to the different mangling conventions? Seems easier to do than to test/document that it doesn't work.
Yes. But the "stdcall" case seems more tedious. Anyway, __float128 is only available in GCC which uses underscore mangling, right?
> 2) I could not make it work --with-clanguage=c++ - I get compilation errors like this. Any idea?
> C++, in all it's template metaprogramming glory, standardized that std::complex may *only* be used with float, double, and long double. Using std::complex<anything_else> is invalid. Just one of a very long list of reasons why std::complex should not be used.
