[petsc-dev] FieldSplit fixes in 3.3
    Hong Zhang
    hzhang at mcs.anl.gov
    Tue Aug 21 11:08:00 CDT 2012
Dmitry :
I pushed a bugfix of mumps interface to 3.3. When merging it to petsc-dev,
I get
merging src/ksp/pc/impls/fieldsplit/fieldsplit.c failed!
Hong
> On Mon, Aug 20, 2012 at 8:36 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Mon, Aug 20, 2012 at 4:02 AM, Dmitry Karpeev <karpeev at mcs.anl.gov>wrote:
>>> On Sun, Aug 19, 2012 at 1:17 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>>> On Sun, Aug 19, 2012 at 12:48 PM, Dmitry Karpeev <karpeev at mcs.anl.gov>wrote:
>>>>> The main reason for this being a patch in 3.3 is that recursive
>>>>> FieldSplit is broken there (which is why I couldn't enable it in
>>>>> libMesh/Moose correctly).
>>>> The current interface doesn't explicitly support all the ways to get
>>>> information into the split, but several people have worked around the
>>>> limitations to get the necessary information in there. Having you and Matt
>>>> changing things to rely on mutually incompatible side-effects does not
>>>> help.
>>> I don't think the present fix is about the API or working through side
>>> effects (nullspace stuff excluded and partially backed out here:
>>> http://petsc.cs.iit.edu/petsc/releases/petsc-3.3/rev/1723d4624521)
>> What do you call this external DM futzing?
> It's no different than holding onto the ISs set in
> PCFieldSplitSetDefaults() or directly via PCFieldSplitSetIS() until they
> can be used in PCSetUp_FieldSplit(). I don't see how this can be avoided
> here or in the future, unless we do something to fundamentally change the
> set up process.
>>>  The current interface assumes that the A00 solver and the Schur inner
>>> solver are to be set up identically
>> If they are being set up identically, they should literally be the same
>> object. This is often the biggest setup cost in the whole problem (e.g.
>> AMG).
> I agree, but that's available only in petsc-dev, not in petsc-3.3.  The
> duplicate setup has been occurring all along, now it is actually consistent
> with the DM being forwarded to the inner solver.
>>> (something we relaxed in petsc-dev).  In order to use fieldsplit on
>>> these solvers the DM for the corresponding split must be forwarded to both
>>> of these A00 solvers.  It was being set only on the "outer" A00 solver.
>>>  Partly this is an artifact of our "split" setup process: some of it occurs
>>> in PCFieldSplitSetDefaults(), some later in PCSetUp_FieldSplit().  Some
>>> objects obtained in PCFieldSplitSetDefaults() need to be cached until
>>> PCSetUp_FieldSplit(), and the splits' DMs are among those. I now put in
>>> proper reference counting for them here:
>>> http://petsc.cs.iit.edu/petsc/releases/petsc-3.3/rev/188af9799779
>>>> Maybe we can reach some agreement on the proper way to do things.
>>> That's fine with me.  The reason I wanted to fix this particular problem
>>> now is that some dependent packages (e.g., Moose) only rely on release
>>> versions of petsc and would not be able to use this functionality properly
>>> for quite some time.
>> Why do packages do this? Because petsc-dev is sometimes unstable.
>> Now what happens when code that is pushed to the release changes behavior
>> and uses uninitialized memory? The release becomes unstable.
>> Even worse, our nightly testing is targeted at petsc-dev because the
>> expectation is that only trivial and well-tested bug-fix patches are pushed
>> to release. If we are changing that model by introducing significant
>> changes, we MUST have nightly tests for the release, we have to actually
>> look at the results, and I would be strongly in favor of switching from
>> 3.3p3 numbering to 3.3.1.
>> In all cases, these subminor or patch releases MUST be binary and
>> source-level backward compatible.
>>> Let's fix that "down the line". Setting a DM should never force it to be
>>>> used or cause an error due to unsupported operation in a case where not
>>>> having a DM is also acceptable.
>>> Currently the inner and outer A00 solvers are essentially identified
>>> (duplicated), so they should be set up identically, including the DM.
>>> Especially when that DM defines a recursive split.  This is in part
>>> because there is no way to configure those two differently programmatically
>>> or from the command line.  So if the outer A00 is using
>>> -fieldsplit_0_pc_type_fieldsplit, the inner A00 will as well.
>>> However, the DM on the inner A00 will be rather different (or absent)
>>> and produce splits incompatible with the rest of the options (e.g.,  a
>>> single default split, while -fieldsplit_0_pc_fieldsplit_type schur).
>>> Incidentally, this raises this question down the road: in petsc-dev the
>>> inner and outer A00 can be configure separately using different prefixes,
>>> but how should the inner A00 DM be configured?
>> The KSPs should only be different if the solver is different. Having them
>> separate, but using the same DM is one reason I was not wild about having
>> physics in the DM, but I don't see a good way to plumb in the extra
>> information. In any case, we need to come up with a solution before pushing
>> code.
>>>  Okay, I'll back out that part of the second patch, since A11's
>>>>> nullspace is assumed to be meant for S.  I'm not sure what's incorrect
>>>>> about the comment, though: if a vector is in the A11's kernel, but not in
>>>>> S's, I call it a "false positive".  This terminology may be wanting, but
>>>>> what's incorrect about it?
>>>> "force an inconsistent rhs"
>>> The KSP solve will fail only if the search space X is contracted to the
>>> point where the rhs b is not in the range AX,  hence,
>>> inconsistent.
>> Okay, I just would have said that it changes the operator. Also, the
>> Krylov methods are not necessarily correct if the matrix does not have the
>> stated null space (since it's expected that the matrix has the null space
>> and only the preconditioner needs to be filtered).
>>> I backed out this hunk, however.
>>>> S may well be nonsingular.
>>>>>> I think that's confusing and we need a specific API for it, but if
>>>>>> people are using it that way, we shouldn't change it in 3.3.
>>>>>>  I'd prefer to backout the first patch, split it into separate
>>>>>> pieces, and review each before pushing. I think it's a potentially big
>>>>>> behavior change for 3.3.
>>>>> Which pieces of the first patch do you think are too big for 3.3?  The
>>>>> splits' and Schur KSPs have to be set up (maybe not all in every situation)
>>>>> in order for recursive splitting to work.  Should we declare that
>>>>> capability unavailable for 3.3?  I can eliminate the unneeded KSPSetUp()
>>>>> calls.
>>>> 1. I hate those hacky dm reference-non-references.
>>>> 2. I don't want unused KSPs to be set up. (We should eventually fix the
>>>> model so they don't exist...)
>>>> 3. Two of the three IncrementTabLevels that you introduced are not
>>>> necessary because the KSP's tab level was incremented before getting the
>>>> PC.
>>> Where?
>>        ierr  =
>> KSPCreate(((PetscObject)pc)->comm,&jac->kspschur);CHKERRQ(ierr);
>>        ierr  =
>> PetscLogObjectParent((PetscObject)pc,(PetscObject)jac->kspschur);CHKERRQ(ierr);
>>        ierr  =
>> PetscObjectIncrementTabLevel((PetscObject)jac->kspschur,(PetscObject)pc,1);CHKERRQ(ierr);
>> +        PC pcschur;
>> +        ierr           = KSPGetPC(jac->kspschur, &pcschur);
>> CHKERRQ(ierr);
>> +        ierr           =
>> PetscObjectIncrementTabLevel((PetscObject)pcschur,(PetscObject)pc,1);CHKERRQ(ierr);
>>    ierr           =
>> KSPCreate(((PetscObject)pc)->comm,&ilink->ksp);CHKERRQ(ierr);
>>    ierr           =
>> PetscObjectIncrementTabLevel((PetscObject)ilink->ksp,(PetscObject)pc,1);CHKERRQ(ierr);
>> +    PC ilinkpc;
>> +    ierr           = KSPGetPC(ilink->ksp, &ilinkpc); CHKERRQ(ierr);
>> +    ierr           =
>> PetscObjectIncrementTabLevel((PetscObject)ilinkpc,(PetscObject)pc,1);CHKERRQ(ierr);
>> This is the pattern used everywhere else in PETSc so that sub-pcs always
>> have the correct tab level.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120821/385a7b46/attachment.html>
