[petsc-dev] Semismooth Newton
    Dmitry Karpeev
    karpeev at mcs.anl.gov
    Thu Aug  2 08:06:08 CDT 2012
On Wed, Aug 1, 2012 at 5:01 PM, Todd Munson <tmunson at mcs.anl.gov> wrote:
> On Aug 1, 2012, at 4:13 PM, Jed Brown wrote:
> > On Wed, Aug 1, 2012 at 11:10 AM, Todd Munson <tmunson at mcs.anl.gov>
> wrote:
> > Yes, I am all in favor of actually specifying a VI externally and then
> > internally formulating the appropriate augmented system.  This is what
> > I do in other contexts (i.e. PATH for GAMS/AMPL).  Some things you
> > probably want to do with such an interface is differentiate between
> > linear and nonlinear constraints -- you do need second derivatives
> > for nonlinear constraints and they should be convex.
> > Why not treat it as always nonlinear with the trivial second derivative
> in the linear case?
> You can if you want.  I would say that one benefit of splitting is that
> sometimes
> roundoff errors can be an issue and isolating the linear parts (which are
> just
> data) from the nonlinear parts may help.  It depends on your Newton method
> though.  Knowing that your constraints are linear also means that you
> do not need to worry about the Hessian of the Lagrangian.  Adding and
> dropping linear constraints is would also seem to be easier since
> there is no penalty to be paid since the Jacobian does not need
> to be modified.
> One interesting thing is that for nonlinear constraints, your Jacobian
> matrix in the upper right hand block is the summation of a general matrix
> (the Jacobian of F(x)) and a symmetric matrix (sum_i lambda_i nabla^2
> c_i(x),
> where lambda is the Lagrange multiplier).  Is there a good matrix storage
> scheme for this combination?
How does one precondition a system like that?  Presumably, the user may at
best be able to provide a preconditioner for JF.
If JF responds well to multigrid, then it may be possible to use AMG-KKT
to coarsen the constraint Hessian, but how does MG perform for the sum
JF + Hc?  There is also the problem of smoothing, although, if JF and Jc
are sparse, then DD may be an option with a direct solve on subdomains.
Anything more definitive on preconditioning these systems?
Dmitry.
> > You can start getting very general (i.e. linear and nonlinear cone
> > constraints, which can appear in contact problems with friction),
> > but I would advocate for simplicity rather than generality.
> > I like simplicity, but I also like not having to change interfaces. I
> would rather write an interface for a more general case and even
> temporarily have an implementation that can't do the fully general thing,
> eventually perhaps doing something more general. We put a rather large
> amount of effort into making TS work with a convenient (solver-friendly)
> representation for DAEs, even though lots of methods cannot be used for
> DAEs. If the general case is not too complicated for the user, I'd rather
> do it that way and internally reformulate.
> The problem with general cones is that they are not easy (you need both a
> definition
> of the cone and the polar cone) and the numerical methods are problematic
> (second-order
> cones, for example, are not differentiable at the origin).  Here you
> require
> interior-point methods.  So, the cone constraints algorithms themselves are
> more of a research issue.
> > The addition and deletion of nonlinear constraints in your example is
> fine.
> > For an active set method, the constraints can be implicitly defined and
> you
> > only need to bring in the new active nonlinear constraints and add them
> to
> > the constraint set for the linear algebra.  You can also do this for
> other
> > methods.  So the active nonlinear constraints can change from one Newton
> > iteration to the next.  The only place where the inactive constraints
> > matter is in the evaluation of the residual for the line search and
> > termination tests.
> > Cool, I'm glad you're happy with the math. Now we need a suitable
> interface, which I think means something a fair amount different from what
> we have now. We need constraint function, its Jacobian, and a Hessian, each
> of which can change size?
> Yep.  I leave it to you to figure this out though.
> > For the contact problems with friction, you typically do an explicit
> > method though.  In this setting, you know the subset of the possible
> > active constraints at each time step and can keep them constant in
> > the VI solver.  They only change as you step forward through time.
> > So you can optimize for this case and not have to worry about the
> > constraints changing within each Newton iteration.
> > I'm not sure how you want to design the variable constraint
> functionality,
> > but there is nothing wrong with it technically.
> > I can explain the semismooth method with slacks thing in a few lines.
> > The simple problem is:
> >   0 <= x  perp  f(x) >= 0
> > The compact semismooth formulation is:
> >   Phi(x,f(x)) = 0
> > where Phi is the reformulation used.
> > The semismooth formulation with slacks is:
> >   f(x) - s = 0
> >   Phi(x,s) = 0
> > The linear algebra for the semismooth reformulation with slacks
> > is very similar to that for the compact formulation, but there
> > are subtle differences in the right hand side and the
> > subdifferential.
> > Do you mean that the slacks are eliminated again in the linear algebra?
> What are the "subtle differences"?
> If you eliminate the slack variables, in the slack formulation, then you
> get
> a system that looks like the semismooth system, but with a different right
> hand side.  Apparently, the difference in the right hand side leads to
> fewer Newton iterations in general.  Not a big deal.
> Cheers, Todd.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120802/4d295278/attachment.html>
