[petsc-dev] error building with petsc-dev
Mark F. Adams
mark.adams at columbia.edu
Mon Apr 30 13:55:26 CDT 2012
Thanks Dmitry,
I think there is something wrong with my kdiff3 (or something like that). I updated this AM and got 100+ conflicts and so I just kept all of my code, and lost the updates to gamg.c and agg.c.
On Apr 30, 2012, at 2:07 PM, Dmitry Karpeev wrote:
> Mark,
> PetscTypeCompare got renamed to PetscObjectTypeCompare in line with the PETSc naming guidelines:
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/3fc8f665421d
> The gamg source was part of this update.
> Any chance you introduced a new instance of PetscTypeCompare() after that changeset?
> If so, simply replace it with PetscObjectTypeCompare().
> Dmitry.
> On Mon, Apr 30, 2012 at 1:03 PM, Mark F. Adams <mark.adams at columbia.edu> wrote:
> I've built petsc-dev but when I try to make an example I get this:
> make ex54
> /Users/markadams/Codes/petsc-dev/arch-macosx-gnu-O/bin/mpicc -o ex54.o -c -malign-double -g3 -fno-inline -O0 -I/Users/markadams/Codes/petsc-dev/include -I/Users/markadams/Codes/petsc-dev/arch-macosx-gnu-O/include -D__INSDIR__=src/ksp/ksp/examples/tutorials/ ex54.c
> /Users/markadams/Codes/petsc-dev/arch-macosx-gnu-O/bin/mpicc -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -malign-double -g3 -fno-inline -O0 -o ex54 ex54.o -L/Users/markadams/Codes/petsc-dev/arch-macosx-gnu-O/lib -lpetsc -ltriangle -lparmetis -lmetis -lHYPRE -lmpichcxx -lstdc++ -lpthread -lflapack -lfblas -lhdf5_fortran -lhdf5 -lhdf5hl_fortran -lhdf5_hl -lz -L/sw/lib/gcc4.6/lib/gcc/i386-apple-darwin10.8.0/4.6.2 -L/sw/lib/gcc4.6/lib -lpmpich -lmpich -lopa -lmpl -lSystem -lgcc_ext.10.5 -ldl -lmpichf90 -lpthread -lgfortran -lgfortran -lquadmath -lm -lm -lmpichcxx -lstdc++ -lpmpich -lmpich -lopa -lmpl -lSystem -lgcc_ext.10.5 -ldl
> Undefined symbols:
> "_PetscTypeCompare", referenced from:
> _PCSetUp_GAMG in libpetsc.a(gamg.c.o)
> ld: symbol(s) not found
> collect2: ld returned 1 exit status
> Any ideas?
> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120430/8adc3270/attachment.html>
