[petsc-dev] What needs to be done before a release?
    Blaise Bourdin
    bourdin at lsu.edu
    Mon Apr 30 10:37:42 CDT 2012
I know I suggested it before and the idea did not get much traction, but it would be _really_
nice to add Real and Integer arrays to PetscBag. The idea is _not_ to add full fields in a bag.
Instead, I would like to be able to pass material properties as command line arguments in a concise way.
(Think of a Hooke's law in 3d and its 21 coefficients, passing it as -a 1,1,1,1,1,... is much nicer than
having to pass -a_1111 1 -a 1122 1 etc).
Also, fortran wrappers over PetscOptionsEnum and PetscBagRegisterEnum would be nice. I understand that it
is a bit tricky since it involves passing fortran arrays of strings.
Blaise
On Apr 29, 2012, at 9:55 PM, Shri wrote:
>> What is left to be done before a release?
>> - Replace 2 DMMG examples
>> - Rework thread code
>    This should hopefully be done by friday.
> Shri
>> Barry
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
