[petsc-dev] 4.2 and PETSc
Daniel Lowell redratio1 at gmail.com
Fri Apr 27 10:53:03 CDT 2012
Even with the new build system I still had to go through and eliminate the
-g3 in petscvariables
CC_FLAGS =  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
-g3 -fno-inline -O0
PCC_LINKER_FLAGS =    -Wall -Wwrite-strings -Wno-strict-aliasing
-Wno-unknown-pragmas -g3 -fno-inline -O0
PCC_FLAGS =  -Wall -Wwrite-strings -Wno-strict-aliasing
On Mon, Apr 23, 2012 at 4:43 PM, Daniel Lowell <redratio1 at gmail.com> wrote:
> Sending the make.log to petsc-maint now.
> On Mon, Apr 23, 2012 at 4:38 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> but you missed copy/pasting the actual compile command. So incomplete
>> info here..
>> satish
>> On Mon, 23 Apr 2012, Daniel Lowell wrote:
>> > I added -v in the local folder's makefile to produce verbose output.
>> > On Mon, Apr 23, 2012 at 4:33 PM, Satish Balay <balay at mcs.anl.gov>
>> wrote:
>> > > Hm - we've seen these errors with -g3 but not with -g. Are you sure
>> > > there is no '-g3' somewhere on the compile command?
>> > > With latest petsc-dev/buildsystem one should not see -g3 [set by
>> configure]
>> > > Also - why is there 'cicc' in a petsc build?
>> > > Satish
>> > > > Hi all,
>> > > > Has anyone run into any problems with NVCC 4.1 or .42 on PETSc with
>> > > > arch=sm_20?
>> > > > I have having real issues with it. I keep getting this:
>> > > > #$ cicc  -arch compute_20 -m64 -ftz=0 -prec_div=1 -prec_sqrt=1
>> -fmad=1 -g
>> > > > -O0 "/tmp/tmpxft_00000b8b_00000000-10_vecgpu"
>> > > > "/tmp/tmpxft_00000b8b_00000000-7_vecgpu.cpp3.i"  -o
>> > > > "/tmp/tmpxft_00000b8b_00000000-2_vecgpu.ptx"
>> > > > <built-in>(2): error: "__STDC_HOSTED__" is predefined; attempted
>> > > > redefinition ignored
>> > > > <built-in>(8): error: "__WCHAR_TYPE__" is predefined; attempted
>> > > > <built-in>(115): error: "__x86_64" is predefined; attempted
>> redefinition
>> > > > ignored
>> > > > <built-in>(116): error: "__x86_64__" is predefined; attempted
>> > > redefinition
>> > > > ignored
>> > > > <built-in>(126): error: "__linux__" is predefined; attempted
>> redefinition
>> > > > ignored
>> > > > <built-in>(128): error: "__unix__" is predefined; attempted
>> redefinition
>> > > > ignored
>> > > > 6 errors detected in the compilation of
>> > > > "/tmp/tmpxft_00000b8b_00000000-7_vecgpu.cpp3.i".
>> > > > # --error 0x1 --
>> > > > 4.0 works fine, no issues.
>> > > > 4.0 version uses the older nvopencc, in 4.1 and 4.2 they use
>> something
>> > > > called cicc, for target architecture sm_2x. Of course it does no
>> mention
>> > > > cicc in the updated nvcc documentation at all.
>> > > > Tried 4.2 with GCC 4.3 and 4.4 without any difference in behavior.
>> > > > PETSc configuration script:
>> > > > MPI_DIR="--with-mpi-dir=$MPICH2_HOME"
>> > > > LAD="--download-f-blas-lapack=yes"
>> > > > CUD="--with-cuda-dir=/soft/cuda-4.2/cuda"
>> > > > ./config/configure.py $MPI_DIR $LAD $CUD \
>> > > > --with-debugging=1 \
>> > > > --with-cudac="nvcc -m64 -g -G" \
>> > > > --with-precision=double \
>> > > > --with-clanguage=c \
>> > > > --with-cuda-arch=sm_20
> Daniel Lowell
Daniel Lowell
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120427/aa5d25c4/attachment.html>
