[petsc-dev] [petsc-users] writing native PETSc binaries in	python
    Ataollah Mesgarnejad
    amesga1 at tigers.lsu.edu
    Fri Apr 27 10:28:41 CDT 2012
Thanks for the replies:
Just a bug report with petsc4py:
petsc4py which downloads with --download-petsc4py=1 is the older v1.1.1
which doesn't compile with petsc-dev?
Ata
On Fri, Apr 27, 2012 at 8:25 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Apr 27, 2012 at 9:19 AM, Ataollah Mesgarnejad <
> amesga1 at tigers.lsu.edu> wrote:
>> Dear all,
>> I was wondering if there is way to write numpy arrays as native PETSc
>>  binaries in python so I can open them inside my program with VecView?
> I think what you want is to create a Vec using that array in petsc4py.
>    Matt
>> Thanks,
>> Ata
> experiments lead.
> -- Norbert Wiener
A. Mesgarnejad
PhD Student, Research Assistant
Mechanical Engineering Department
Louisiana State University
2203 Patrick F. Taylor Hall
Baton Rouge, La 70803
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120427/cca3e1b6/attachment.html>
