[petsc-dev] MatAXPY with DIFFERENT_NONZERO_PATTERN
Jed Brown
jedbrown at mcs.anl.gov
Mon Apr 23 08:12:26 CDT 2012
My fault, now fixed:
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/8a997a5a65d3
On Mon, Apr 23, 2012 at 02:39, Alexander Grayver <agrayver at gfz-potsdam.de>wrote:
> Jed,
> Thanks. However:
> [ 19%] Building C object
> CMakeFiles/petsc.dir/src/sys/ftn-custom/zstartf.c.o
> [ 19%] Building C object CMakeFiles/petsc.dir/src/sys/ftn-custom/zsys.c.o
> Building C object CMakeFiles/petsc.dir/src/sys/ftn-custom/zutils.c.o
> /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-dev1/src/sys/ftn-custom/zstart.c(117):
> error: expected a type specifier
> extern MPI_Op MPIU_SUM;
> error: "MPI_Op" has already been declared in the current scope
> /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-dev1/src/sys/ftn-custom/zstart.c(128):
> error: function "MPI_Op" is not a type name
> extern MPI_Op PetscMaxSum_Op;
> /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-dev1/src/sys/ftn-custom/zstart.c(220):
> extern MPI_Op PetscADMax_Op;
> /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-dev1/src/sys/ftn-custom/zstart.c(221):
> extern MPI_Op PetscADMin_Op;
> /panfs/panfs.gfz-hpcc.cluster/home/mt/agrayver/lib/petsc-dev1/src/sys/ftn-custom/zstart.c(343):
> error: expression must be an lvalue or a function designator
> *ierr = MPI_Op_create(PetscSum_Local,1,&MPIU_SUM);
> On 23.04.2012 03:23, Jed Brown wrote:
> Thanks for the test case. Fixed here:
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/7ac7040f19d7
> On Sun, Apr 22, 2012 at 08:11, Alexander Grayver <agrayver at gfz-potsdam.de>wrote:
>> Matt,
>> Here are matrices (double complex, 3 MB each):
>> http://dl.dropbox.com/u/60982984/X.dat
>> http://dl.dropbox.com/u/60982984/Y.dat
>> Code:
>> static char help[] = "";
>> int main(int argc,char **args)
>> Mat A,B;
>> PetscErrorCode ierr;
>> PetscViewer viewer;
>> PetscScalar cone;
>> PetscInitialize(&argc,&args,(char *)0,help);
>> ierr =
>> PetscViewerBinaryOpen(PETSC_COMM_WORLD,"Y.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
>> ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
>> ierr = MatSetFromOptions(A);CHKERRQ(ierr);
>> ierr = MatLoad(A,viewer);CHKERRQ(ierr);
>> ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
>> ierr =
>> PetscViewerBinaryOpen(PETSC_COMM_WORLD,"X.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr);
>> ierr = MatCreate(PETSC_COMM_WORLD,&B);CHKERRQ(ierr);
>> ierr = MatSetFromOptions(B);CHKERRQ(ierr);
>> ierr = MatLoad(B,viewer);CHKERRQ(ierr);
>> cone = 1.0;
>> ierr = MatAYPX(A,cone,B,DIFFERENT_NONZERO_PATTERN);
>> ierr = PetscFinalize();
>> return 0;
>> It works fine if you run it with:
>> mpirun -n 10 solveTest -mat_type aij
>> and crashes if n > 10
>> Thanks.
>> On 22.04.2012 14:51, Matthew Knepley wrote:
>> On Sun, Apr 22, 2012 at 8:41 AM, Alexander Grayver <
>> agrayver at gfz-potsdam.de> wrote:
>>> Sorry, I don't quite get. Is this something I can avoid by doing
>>> preallocation properly or petsc issue that will be fixed?
>> This looks like a PETSc bug to me, but it would be nice to get input
>> that triggers it.
>> Thanks,
>> Matt
>>> On 20.04.2012 14:23, Jed Brown wrote:
>>> On Fri, Apr 20, 2012 at 05:18, Matthew Knepley <knepley at gmail.com>wrote:
>>>> Did someone intend to fix this, and then
>>>> stop? MatAXPY_BasicWithPreallocation() is the same as MatAXPY_Basic().
>>> Look how it's called. I don't know what's going on here.
>>> ierr =
>>> MatAXPYGetPreallocation_SeqAIJ(yy->A,xx->A,nnz_d);CHKERRQ(ierr);
>>> ierr =
>>> MatAXPYGetPreallocation_SeqAIJ(yy->B,xx->B,nnz_o);CHKERRQ(ierr);
>>> ierr = MatMPIAIJSetPreallocation(B,0,nnz_d,0,nnz_o);CHKERRQ(ierr);
>>> ierr = MatAXPY_BasicWithPreallocation(B,Y,a,X,str);CHKERRQ(ierr);
>>> Regards,
>>> Alexander
>> experiments lead.
>> -- Norbert Wiener
>> Regards,
>> Alexander
> Regards,
> Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120423/dc46e85b/attachment.html>
