[petsc-dev] Recommended Petsc Build Procedure
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Apr 22 10:53:02 CDT 2012
   The recommend usage is  make
    If cmake was found with ./configure it will use it automatically if you do make, if it was not found it will use the legacy make
   Barry
On Apr 22, 2012, at 10:19 AM, Dave Nystrom wrote:
> OK.  I'll mail the configure.log to petsc-maint.  But this did not start out
> as a configure problem - I was just asking for a recommendation on usage.
> And the response you cite below was to Aron before I received your response.
> Matthew Knepley writes:
>> On Sun, Apr 22, 2012 at 10:57 AM, Dave Nystrom <Dave.Nystrom at tachyonlogic.com> wrote:
>>> I have cmake on my system but configure.log does not document that
>>> approach.
>> We did not find it. This is a configure question, and should be mailed to
>> petsc-maint, not the dev list.
>>> What is your build command to build petsc with cmake?
>> make
>>   Matt
>>> Thanks,
>>> Dave
>>> Aron Ahmadia writes:
>>>> I use the CMake build because it's the fastest, though it requires you
>>> to
>>>> have CMake installed on your system.
>>>> A
>>>> On Sun, Apr 22, 2012 at 5:42 PM, Dave Nystrom <Dave.Nystrom at tachyonlogic.com> wrote:
>>>>> At the end of configure.log, there are two possible ways to build
>>> petsc-dev
>>>>> that are specified.  Which is the recommended way to build - using
>>> make or
>>>>> using python?  I have been using make.
>>>>> Also, one is labeled as legacy and one is labeled as experimental.
>>> That
>>>>> gives the impression of having a choice between an old, archaic
>>> method or a
>>>>> new, experimental approach.  Should one just be labeled as production?
>>>>> Thanks,
>>>>> Dave
>> experiments lead.
>> -- Norbert Wiener
