[petsc-dev] Recommended Petsc Build Procedure
    Matthew Knepley
    knepley at gmail.com
    Sun Apr 22 10:03:48 CDT 2012
On Sun, Apr 22, 2012 at 10:57 AM, Dave Nystrom <
Dave.Nystrom at tachyonlogic.com> wrote:
> I have cmake on my system but configure.log does not document that
> approach.
We did not find it. This is a configure question, and should be mailed to
petsc-maint, not the dev list.
> What is your build command to build petsc with cmake?
make
   Matt
> Thanks,
> Dave
> Aron Ahmadia writes:
>  > I use the CMake build because it's the fastest, though it requires you
> to
>  > have CMake installed on your system.
>  > A
>  > On Sun, Apr 22, 2012 at 5:42 PM, Dave Nystrom <
>  > > wrote:
>  > > At the end of configure.log, there are two possible ways to build
> petsc-dev
>  > > that are specified.  Which is the recommended way to build - using
> make or
>  > > using python?  I have been using make.
>  > > Also, one is labeled as legacy and one is labeled as experimental.
>  That
>  > > gives the impression of having a choice between an old, archaic
> method or a
>  > > new, experimental approach.  Should one just be labeled as production?
>  > > Thanks,
>  > > Dave
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120422/7cab705a/attachment.html>
