[petsc-dev] pip cannot currently automatically download and install petsc on OS X
Aron Ahmadia
aron.ahmadia at kaust.edu.sa
Wed Apr 18 07:47:18 CDT 2012
The mpif90 on OS X.3-6 is a non-functional little script installed by the
OpenMPI folks that mpi4py happily picks up and reports as installed. We
need to patch mpi4py to correctly detect this little piece of
disfunctionality as non-existent.
sudo rm /usr/bin/mpif90 and a reinstall of mpi4py fixes that issue :)
A
On Wed, Apr 18, 2012 at 3:39 PM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>wrote:
> Bogus! This is coming from a bad mpi4py install on my box!
> On Wed, Apr 18, 2012 at 3:25 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Wed, Apr 18, 2012 at 8:18 AM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>wrote:
>>> Lisandro has fixed the first issue, but another has sprung up in its
>>> place:
>>> pip seems to be installing the packages out of order and insists on
>>> building petsc4py before petsc. We still have the issue with petsc wanting
>>> mpif90 available on OS X...
>> Where are the configure arguments stored so I can look at them?
>> Matt
>>> A
>>> On Wed, Apr 18, 2012 at 2:57 PM, Aron Ahmadia <aron at ahmadia.net> wrote:
>>>> This is on an OS X.6 box running Python 2.7 and pip 1.0.2
>>>> # at command line:
>>>> pip install -vvv petsc4py
>>>> # relevant bits:
>>>> Downloading/unpacking petsc>=3.2,<3.3 (from petsc4py)
>>>> Getting page http://pypi.python.org/simple/petsc
>>>> URLs to search for versions for petsc>=3.2,<3.3 (from petsc4py):
>>>> * http://pypi.python.org/simple/petsc/
>>>> Getting page http://www.mcs.anl.gov/petsc/
>>>> Skipping page
>>>> http://ftp.mcs.anl.gov/pub/petsc/release-snapshots/petsc-lite-3.2-p6.tar.gz(from
>>>> http://pypi.python.org/simple/petsc/) because of Content-Type:
>>>> application/x-gzip
>>>> Found link
>>>> http://pypi.python.org/simple/petsc/), version: lite-3.2-p6
>>>> The "lite-" prefix is being interpreted as part of the version, which
>>>> pip doesn't quite know what to do with. It would probably just be easiest
>>>> to host lite versions in a separate directory
>>>> ../release-snapshots/lite/petsc-3.2-p6.tar.gz that petsc4py/PyPI can point
>>>> to. Lisandro can also point to the non-lite versions until a solution is
>>>> implemented.
>>>> This is going to be an additional problem:
>>>> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
>>>> for details):
>>>> Fortran compiler you provided with --with-fc=/usr/bin/mpif90 does not
>>>> work
>>>> Obviously the Mac doesn't come with /usr/bin/mpif90, so a clean system
>>>> won't have this either... I think you guys know your options for how to
>>>> fix this, but let me know if you want my 2 cents :)
>>>> =AA=
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120418/3567907f/attachment.html>
