[petsc-dev] pip cannot currently automatically download and install petsc on OS X
Matthew Knepley
knepley at gmail.com
Wed Apr 18 07:25:58 CDT 2012
On Wed, Apr 18, 2012 at 8:18 AM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>wrote:
> Lisandro has fixed the first issue, but another has sprung up in its place:
> pip seems to be installing the packages out of order and insists on
> building petsc4py before petsc. We still have the issue with petsc wanting
> mpif90 available on OS X...
Where are the configure arguments stored so I can look at them?
Matt
> A
> On Wed, Apr 18, 2012 at 2:57 PM, Aron Ahmadia <aron at ahmadia.net> wrote:
>> This is on an OS X.6 box running Python 2.7 and pip 1.0.2
>> # at command line:
>> pip install -vvv petsc4py
>> # relevant bits:
>> Downloading/unpacking petsc>=3.2,<3.3 (from petsc4py)
>> Getting page http://pypi.python.org/simple/petsc
>> URLs to search for versions for petsc>=3.2,<3.3 (from petsc4py):
>> * http://pypi.python.org/simple/petsc/
>> Getting page http://www.mcs.anl.gov/petsc/
>> Skipping page
>> http://ftp.mcs.anl.gov/pub/petsc/release-snapshots/petsc-lite-3.2-p6.tar.gz(from
>> http://pypi.python.org/simple/petsc/) because of Content-Type:
>> application/x-gzip
>> Found link
>> http://pypi.python.org/simple/petsc/), version: lite-3.2-p6
>> The "lite-" prefix is being interpreted as part of the version, which pip
>> doesn't quite know what to do with. It would probably just be easiest to
>> host lite versions in a separate directory
>> ../release-snapshots/lite/petsc-3.2-p6.tar.gz that petsc4py/PyPI can point
>> to. Lisandro can also point to the non-lite versions until a solution is
>> implemented.
>> This is going to be an additional problem:
>> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
>> details):
>> Fortran compiler you provided with --with-fc=/usr/bin/mpif90 does not work
>> Obviously the Mac doesn't come with /usr/bin/mpif90, so a clean system
>> won't have this either... I think you guys know your options for how to
>> fix this, but let me know if you want my 2 cents :)
>> =AA=
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120418/2f1a186b/attachment.html>
