[petsc-dev] pip cannot currently automatically download and install petsc on OS X
Aron Ahmadia aron at ahmadia.net
Wed Apr 18 06:57:33 CDT 2012
This is on an OS X.6 box running Python 2.7 and pip 1.0.2
# at command line:
pip install -vvv petsc4py
# relevant bits:
Downloading/unpacking petsc>=3.2,<3.3 (from petsc4py)
  Getting page http://pypi.python.org/simple/petsc
  URLs to search for versions for petsc>=3.2,<3.3 (from petsc4py):
  * http://pypi.python.org/simple/petsc/
  Getting page http://www.mcs.anl.gov/petsc/
  Skipping page
http://ftp.mcs.anl.gov/pub/petsc/release-snapshots/petsc-lite-3.2-p6.tar.gz(from
http://pypi.python.org/simple/petsc/) because of Content-Type:
application/x-gzip
    Found link
http://pypi.python.org/simple/petsc/), version: lite-3.2-p6
The "lite-" prefix is being interpreted as part of the version, which pip
doesn't quite know what to do with.  It would probably just be easiest to
host lite versions in a separate directory
../release-snapshots/lite/petsc-3.2-p6.tar.gz that petsc4py/PyPI can point
to.  Lisandro can also point to the non-lite versions until a solution is
implemented.
This is going to be an additional problem:
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
Fortran compiler you provided with --with-fc=/usr/bin/mpif90 does not work
Obviously the Mac doesn't come with /usr/bin/mpif90, so a clean system
won't have this either...  I think you guys know your options for how to
fix this, but let me know if you want my 2 cents :)
=AA=
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120418/b1830977/attachment.html>
