[petsc-dev] PCApplyTranspose in BiCG
Alexander Grayver
agrayver at gfz-potsdam.de
Wed Apr 18 02:20:46 CDT 2012
Jed,
Thank you.
TFQMR works well now, however TCQMR doesn't. Although latter was working
before I updated petsc-dev. Might be same issue?
On 18.04.2012 07:30, Jed Brown wrote:
> Thanks for the details, we should have identified the issue earlier.
> When VecDot changed from using custom code to BLAS xDOT, the
> conjugation definition was accidentally changed. If you pull after
> this patch, TFQMR will work for your problem again.
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/8f37c498b7b4
> On Wed, Apr 11, 2012 at 00:38, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
> On 10.04.2012 14:19, Jed Brown wrote:
>> There is no space allocated at (44,44); note that counting is
>> 0-based. This consistency check has been in PETSc for many years,
>> so I don't know why you didn't trip it in earlier runs. Do you
>> have some options in PETSC_OPTIONS or .petscrc?
> Jed,
> This is not possible:
> >> A = PetscBinaryRead('A.dat','complex',true);
> >> find(diag(A)==0)
> ans =
> Empty matrix: 0-by-1
> >> A(45,45)
> ans = (1,1) 7.999999999999997e+002 +6.316546778308559e-009i
> Sorry, I forgot to mention that this is double complex matrix and
> vector. Have you read it as real double?
>> If it is of any help files are here:
>> http://dl.dropbox.com/u/60982984/A.dat
>> http://dl.dropbox.com/u/60982984/RHS.dat
>> Is this possible to look up changes in one file only?
>> $ hg log src/ksp/ksp/impls/tfqmr/
>> But the problem was clearly not in that file.
> Regards,
> Alexander
Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120418/6b34b559/attachment.html>
