[petsc-dev] various dot products messed up for complex numbers?
    Jed Brown
    jedbrown at mcs.anl.gov
    Wed Apr 18 00:28:04 CDT 2012
On Tue, Apr 17, 2012 at 20:17, Barry Smith <bsmith at mcs.anl.gov> wrote:
> The truth is likely that except for CG most of the methods were coded
> without regard to complex and are likely wrong but not necessarily wrong in
> a consistent way or even self-consistently wrong.
This fixes Alexander Grayver's reported problem with TFQMR. I still don't
know if CG is correct, but it should be easy to check.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120417/36b57626/attachment.html>
