[petsc-dev] various dot products messed up for complex numbers?
Sun Apr 15 12:42:10 CDT 2012
   VecDot - Computes the vector dot product.
   Collective on Vec
   Input Parameters:
.  x, y - the vectors
   Output Parameter:
.  val - the dot product
   Performance Issues:
$    per-processor memory bandwidth
$    interprocessor latency
$    work load inbalance that causes certain processes to arrive much earlier than others
   Notes for Users of Complex Numbers:
   For complex vectors, VecDot() computes
$     val = (x,y) = y^H x,
   where y^H denotes the conjugate transpose of y.
   Use VecTDot() for the indefinite form
$     val = (x,y) = y^T x,
   where y^T denotes the transpose of y.
   Level: intermediate
   Concepts: inner product
   Concepts: vector^inner product
.seealso: VecMDot(), VecTDot(), VecNorm(), VecDotBegin(), VecDotEnd()
   VecTDot - Computes an indefinite vector dot product. That is, this
   routine does NOT use the complex conjugate.
   Collective on Vec
   Input Parameters:
   Output Parameter:
   For complex vectors, VecTDot() computes the indefinite form
   Use VecDot() for the inner product
   Level: intermediate
   Concepts: inner product^non-Hermitian
   Concepts: non-Hermitian inner product
.seealso: VecDot(), VecMTDot()
But source code has
PetscErrorCode VecDot_Seq(Vec xin,Vec yin,PetscScalar *z)
  const PetscScalar *ya,*xa;
  PetscBLASInt      one = 1,bn = PetscBLASIntCast(xin->map->n);
  PetscErrorCode    ierr;
  PetscFunctionBegin;
  ierr = VecGetArrayRead(xin,&xa);CHKERRQ(ierr);
  ierr = VecGetArrayRead(yin,&ya);CHKERRQ(ierr);
  *z = BLASdot_(&bn,xa,&one,ya,&one);
  ierr = VecRestoreArrayRead(xin,&xa);CHKERRQ(ierr);
  ierr = VecRestoreArrayRead(yin,&ya);CHKERRQ(ierr);
  if (xin->map->n > 0) {
    ierr = PetscLogFlops(2.0*xin->map->n-1);CHKERRQ(ierr);
  PetscFunctionReturn(0);
#undef __FUNCT__
#define __FUNCT__ "VecTDot_Seq"
PetscErrorCode VecTDot_Seq(Vec xin,Vec yin,PetscScalar *z)
  PetscBLASInt      one = 1, bn = PetscBLASIntCast(xin->map->n);
  PetscFunctionBegin;
How can they both use BLASdot() when one is supposed to use the complex conjugate of y the second argument.
Note also
      DOUBLE COMPLEX FUNCTION ZDOTC(N,ZX,INCX,ZY,INCY)
*     .. Scalar Arguments ..
      INTEGER INCX,INCY,N
*     .. Array Arguments ..
      DOUBLE COMPLEX ZX(*),ZY(*)
*  Purpose
*  ZDOTC forms the dot product of a vector.
*  Further Details
*     jack dongarra, 3/11/78.
*     modified 12/3/93, array(1) declarations changed to array(*)
         IX = 1
         IY = 1
         IF (INCX.LT.0) IX = (-N+1)*INCX + 1
         IF (INCY.LT.0) IY = (-N+1)*INCY + 1
         DO I = 1,N
            ZTEMP = ZTEMP + DCONJG(ZX(IX))*ZY(IY)
            IX = IX + INCX
            IY = IY + INCY
         END DO
      END IF
      ZDOTC = ZTEMP
uses the complex conjugate of the FIRST argument.
So it looks like everything is major broken for the complex case.
   Barry
