[petsc-dev] Reminder: *every* symbol with extern linkage *must*	be namespaced
    Jed Brown
    jedbrown at mcs.anl.gov
    Sun Apr 15 10:34:58 CDT 2012
On Sat, Mar 17, 2012 at 13:16, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> I have fixed the logging variables and a few others. The following
> incantation will show you a list of the symbols that are not currently in a
> "claimed" namespace (either directly or through bundling). These are
> arguably already too promiscuous, but the symbols that this does not filter
> out should probably be fixed.
> $ nm --print-file-name mpich-static/lib/libpetsc.a |sort -k 3 | grep '
> \(B\|D\|C\|T\) ' | grep -i -v '
> \(XXT\|XYT\|Xi\|TetGen\|Vec\|Mat\|Petsc\|KSP\|PC\|SNES\|DM\|TS\|PF\|IS\|AO\|Characteristic\|ClassPerf\|EventPerfLog\|EventRegLog\|spbas_\|f90array\|mpifcmb\|SPARSEPACK\|MPIU_\|MINPACK\|admf_\)'
Why does PETSc use the MPIU_ prefix? MPICH2 uses it internally for
"utility" routines. Should that stuff become PetscMPI_ or similar?
http://wiki.mcs.anl.gov/mpich2/index.php/Function_Name_Prefix_Convention
Also, perhaps we should set up a board like this to highlight global naming
violations.
http://www.mcs.anl.gov/research/projects/mpich2/todo/globsyms.htm
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120415/4c53f54f/attachment.html>
