[petsc-dev] Configuring for atomics
Jed Brown
jedbrown at mcs.anl.gov
Sat Apr 14 11:44:13 CDT 2012
Lots of other compilers support GCC-style intrinsics like
__sync_bool_compare_and_swap() and similar, so we really can't be doing
this kind of logic in lockfree.c.
#if __ENVIRONMENT_MAC_OS_X_VERSION_MIN_REQUIRED__ >= 1050
#define PetscAtomicCompareandSwap(ptr, oldval, newval)
(OSAtomicCompareAndSwapPtr(oldval,newval,ptr))
#elif defined(_MSC_VER)
(InterlockedCompareExchange(ptr,newval,oldval))
#elif (__GNUC__ * 10000 + __GNUC_MINOR__ * 100 + __GNUC_PATCHLEVEL__) >
40100
(__sync_bool_compare_and_swap(ptr,oldval,newval))
#else
# error No maping for PetscAtomicCompareandSwap
#endif
What does everyone else think about using Dave Goodell's Open Portable
Atomics (https://trac.mcs.anl.gov/projects/openpa/, used by MPICH2) instead
of maintaining our own suite of configuration tests?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120414/d17f363e/attachment.html>
