[petsc-dev] GMRES and eigen estimates
    Mark F. Adams
    mark.adams at columbia.edu
    Tue Apr  3 15:46:14 CDT 2012
Sorry false alarm.
Running in KSP tutorials (this creates a GASM PC that is just one block with the whole domain):
./ex54 -ne 5 -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -pc_gamg_verbose 2 -pc_gamg_use_agg_gasm -mat_coarsen_type hem -pc_gamg_square_graph false -mg_levels_sub_pc_type lu -gamg_est_ksp_type gmres -options_left -ksp_monitor -gamg_est_ksp_monitor_singular_value -gamg_est_ksp_view
I get:
  0 KSP Residual norm 6.446415297424e+01 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
  1 KSP Residual norm 2.366096117202e-14 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
  2 KSP Residual norm 1.540964857879e-14 % max 1.693380955892e+00 min 7.781997678493e-01 max/min 2.176023465763e+00
  3 KSP Residual norm 1.241326996942e-14 % max 2.530597391197e+00 min 7.364405777662e-01 max/min 3.436254692636e+00
  4 KSP Residual norm 1.063574617851e-14 % max 3.476067169257e+00 min 7.236790329140e-01 max/min 4.803327181195e+00
  5 KSP Residual norm 9.458672353406e-15 % max 4.436589616128e+00 min 7.159721822673e-01 max/min 6.196594959987e+00
  6 KSP Residual norm 8.601272732515e-15 % max 5.409099625105e+00 min 7.111665034107e-01 max/min 7.605953878822e+00
  7 KSP Residual norm 7.941524085286e-15 % max 6.390434791698e+00 min 7.078275282801e-01 max/min 9.028237157187e+00
  8 KSP Residual norm 7.413487448731e-15 % max 7.377240678599e+00 min 7.053779875665e-01 max/min 1.045856378939e+01
  9 KSP Residual norm 6.978470326179e-15 % max 8.367510521210e+00 min 7.035029387897e-01 max/min 1.189406619339e+01
 10 KSP Residual norm 6.612020575839e-15 % max 9.360078579306e+00 min 7.020212846961e-01 max/min 1.333304101080e+01
The problem is that I turn off norms for this -- its in the eigen estimate -- because I don't usually want them.  Here they would have stopped the iterations and all would have been good.
BTW, CG does this:
  0 KSP Residual norm 0.000000000000e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
  1 KSP Residual norm 0.000000000000e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
  2 KSP Residual norm 0.000000000000e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
  3 KSP Residual norm 0.000000000000e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
  4 KSP Residual norm 0.000000000000e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
  5 KSP Residual norm 0.000000000000e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
  6 KSP Residual norm 0.000000000000e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
  7 KSP Residual norm 0.000000000000e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
                        PCSetUp_GAMG PC setup max eigen=1.000000e+00 min=0.000000e+00 on level 1 (N=36)
Is it using a preconditioned norm perhaps....
On Apr 3, 2012, at 2:06 PM, Barry Smith wrote:
> barry-smiths-macbook-pro:tutorials barrysmith$ ./ex10 -f0 ~/Datafiles/Matrices/arco1 -pc_type lu -ksp_type gmres -ksp_monitor_singular_value
>  0 KSP Residual norm 2.544968574075e+03 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
>  1 KSP Residual norm 2.708628636814e-10 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
> Number of iterations =   1
> Residual norm 2.36559e-11
> barry-smiths-macbook-pro:tutorials barrysmith$ ./ex10 -f0 ~/Datafiles/Matrices/arco1 -pc_type lu -ksp_type fgmres -ksp_monitor_singular_value
>  0 KSP Residual norm 7.410897708964e+00 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
>  1 KSP Residual norm 2.157675690523e-11 % max 9.999999999999e-01 min 9.999999999999e-01 max/min 1.000000000000e+00
> Residual norm 2.26094e-11
> barry-smiths-macbook-pro:tutorials barrysmith$ ./ex10 -f0 ~/Datafiles/Matrices/arco1 -pc_type lu -ksp_type cg -ksp_monitor_singular_value
>  1 KSP Residual norm 3.135993325987e-10 % max 9.999999999999e-01 min 9.999999999999e-01 max/min 1.000000000000e+00
> Residual norm 2.22684e-11
>  Mark,
>   Could you provide the exact specifications on how you obtained this bad highest eigen estimate? What code you ran with what options?
>    Thanks
>    barry
> On Mar 30, 2012, at 10:22 AM, Mark F. Adams wrote:
>> I've had problems with GMRES and eigen estimates in the past but I now have a smoking gun.  It seems that if you give GMRES an operator preconditioned with LU (ie, the preconditioned operator is the identity) GMRES gives me a highest eigen estimate of ~10 (way off).  With CG I get a prefect max=1.0, min=0.0.
>> Any thoughts?
>> Mark
