[petsc-dev] Module missing error with petsc-dev.
    Satish Balay
    balay at mcs.anl.gov
    Tue Sep 27 20:25:26 CDT 2011
I don't see this error. My cofigure went thorugh fine [on linux]
Satish
Configure Options: --configModules=PETSc.Configure --optionsModule=PETSc.compilerOptions --with-mpi-dir=/home/balay/soft/linux64/mpich2-1.1 --with-shared-libraries=1 --with-clanguage=cxx PETSC_ARCH=asterix64-cxx-mumps --download-parmetis=1 --download-blacs=1 --download-scalapack=1 --download-mumps=1 --download-hypre=1 --with-valgrind=1
On Tue, 27 Sep 2011, Vijay S. Mahadevan wrote:
> I just pulled the dev version (source+Buildsystem) and the reconfigure
> yields errors regarding FIAT module. I do not even have the module as
> part of the configure options. Here's the command.
> ./configure --download-blacs=1 --download-hypre=1 --download-mumps=1
> --download-parmetis=1 --download-scalapack=1
> --known-mpi-shared-libraries=1
> --with-blas-lapack-lib=/System/Library/Frameworks/vecLib.framework/vecLib
> --with-cc=mpicc --with-clanguage=C++ --with-fc=mpif90 --with-mpi=1
> --with-shared-libraries=1 --with-valgrind=1 -with-cxx=mpicxx
> COPTFLAGS="-O3 -ftree-vectorize" CXXOPTFLAGS="-O3 -ftree-vectorize"
> FOPTFLAGS="-O3 -ftree-vectorize" PETSC_ARCH=arch-darwin-cxx-debug
>              Configuring PETSc to compile on your system
>                      UNABLE to FIND MODULE for ./configure
> No module named Fiat
>   File "./config/configure.py", line 269, in petsc_configure
>     framework =
> config.framework.Framework(['--configModules=PETSc.Configure','--optionsModule=PETSc.compilerOptions']+sys.argv[1:],
> loadArgDB = 0)
>   File "/Users/mahadevan/source/petsc-dev/config/BuildSystem/config/framework.py",
> line 110, in __init__
>     self.createChildren()
> line 316, in createChildren
>     self.getChild(moduleName)
> line 301, in getChild
>     config.setupDependencies(self)
>   File "/Users/mahadevan/source/petsc-dev/config/PETSc/Configure.py",
> line 61, in setupDependencies
>     utilityObj                    =
> self.framework.require('PETSc.'+d+'.'+utilityName, self)
> line 321, in require
>     config = self.getChild(moduleName, keywordArgs)
>   File "/Users/mahadevan/source/petsc-dev/config/PETSc/packages/FFC.py",
> line 11, in setupDependencies
>     self.fiat = self.framework.require('config.packages.Fiat', self)
> line 274, in getChild
>     type   = __import__(moduleName, globals(), locals(),
> ['Configure']).Configure
> The log file does not have anything other than push-pop languages. I
> didn't see any issues when I pulled the source. Ideas ?
> Vijay
