[petsc-dev] use of hash table vs array in various places in PETSc
Matthew Knepley
knepley at gmail.com
Tue Sep 20 11:22:23 CDT 2011
On Tue, Sep 20, 2011 at 8:43 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Sep 20, 2011 at 01:05, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> It may very well be limiting with MatGetSubMatrix() for VI solvers.
> As I recall, the gather is used to identify which global columns out of the
> off-diagonal block are needed. Well, the process owning that part of the
> index set knows, so why not use the scatter for the off-diagonal block to
> mark the needed columns?
> This seems quite straightforward when the submatrix is taking a local
> subset (not moving rows to different processes). This also takes care of the
> most common use case in fieldsplit.
> This would be even nicer if we could move indices over the same channels as
> scalars. This comes up so frequently that I think we should build a
> type-independent scatter, something like
> PetscScatterCreate(PetscLayout from,IS isfrom,PetscLayout to,IS
> isto,PetscScatter*);
> PetscScatterBegin(PetscScatter,void *from,MPI_Datatype,void
> *to,MPI_Datatype,MPI_Op,ScatterMode);
> The VecScatter API could be preserved, but the implementation would become
> a thin wrapper over this thing.
Wait, a type-independent Scatter? The one I have been begging for for 7
years, and finally coded myself (see ParallelMapping.hh) suboptimally. I
would like to see VecScatter completely refactored. We need
- Flexible types
- Flexible combination function
- Better linkage to DM
Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110920/fe8c0073/attachment.html>
