[petsc-dev] syntax error in petscmat.h90/petscvec.h90
Alexander Grayver
agrayver at gfz-potsdam.de
Tue Sep 20 03:11:30 CDT 2011
Hi Jed,
For me the fix was to delete & in case there is empty line after it. But
I guess this situation might be fixed in your generator since anyway
such a construction makes no sense:
subroutine VecGhostUpdateBegin(g, insertmode, scattermode ,ierr)&
and is equal to:
Alexander
On 20.09.2011 09:49, Jed Brown wrote:
> On Tue, Sep 20, 2011 at 09:36, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
> Hello Petsc team,
> Since petsc-3.1-p7 I observe insignificant but annoying syntax
> error which occurs in petscmat.h90/petscvec.h90 and have to fix it
> manually when make petsc.
> I use Intel Fortran 11.1 compiler and errors is following:
> /home/lib/petsc-3.2-p2/include/finclude/ftn-auto/petscvec.h90(620): error
> #5153: Illegal continuation. No valid non_commentary source
> following &.
> It looks like the line length calculation has an off-by-one error, so
> it incorrectly puts a continuation when none is needed. Not sure why
> the compiler chokes on this (does the standard actually disallow it?),
> but the fix is to fix the line length calculation.
> /home/lib/petsc-3.2-p2/include/finclude/ftn-auto/petscvec.h90(621): error
> #5082: Syntax error, found '=' when expecting one of: ) ,
> integer(kind=selected_int_kind(10)) g !
> It happens due to this:
> ,ierr)&
> & ! <<<<<<<<<<<< ERROR
> Vec g ! Vec
> InsertMode insertmode ! InsertMode
> ScatterMode scattermode ! ScatterMode
> integer ierr
> end subroutine
> subroutine VecGhostUpdateEnd(g, insertmode, scattermode ,ierr)
> Vec g ! Vec
> integer ierr
> end subroutine
> If I delete & everything is ok. Moreover, I don's see any reason
> to have it there...
> Is it my specific compiler options or what?
> Regards,
> Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110920/58a522ff/attachment.html>
