[petsc-dev] use of hash table vs array in various places in PETSc
Mon Sep 19 18:11:46 CDT 2011
On Tue, Sep 20, 2011 at 01:05, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 19, 2011, at 4:47 PM, Jed Brown wrote:
> > On Mon, Sep 19, 2011 at 23:29, Mark F. Adams <mark.adams at columbia.edu>
> wrote:
> > An alternative to a virtual function is changing the hash table code:
> > #define HASH_FACT 79943
> > #define HASHT(ta,x) ((unsigned long)((HASH_FACT*(unsigned
> long)x)%ta->tablesize))
> > and make HASH_FACT a variable.  Set HASH_FACT  to 1 if you want an array
> (and thus the index (x) is less than the table size tablesize).  The index x
> is one based so the hash function should modified:
> long)(x-1))%ta->tablesize))
> > This is an interesting idea. Storage is still double the array, but I
> think the cases where we want a dense array will generally not be so space
> limited.
>   It may very well be limiting with MatGetSubMatrix() for VI solvers. In
> fact we may need yet a different approach to make the MatGetSubMatrix()
> itself memory scalable for very large problems; that is rather than doing an
> ISAllGather on the columns it has to be smart about knowing what processes
> need to know about what columns based on the sparsity of the matrix.
Oh, you're working with the global column space? That explains why it's so
expensive. This gather is a problem in PCFieldSplit too unless you use
MatNest (which should be easy now). VI doesn't have that luxury, so
MatGetSubMatrix() needs to get a scalable implementation. Didn't we talk
about this several months ago and Dmitry started writing code for it? How
did that turn out?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110920/f59da889/attachment.html>
