[petsc-dev] use of hash table vs array in various places in PETSc
Jed Brown
jedbrown at mcs.anl.gov
Mon Sep 19 16:47:57 CDT 2011
On Mon, Sep 19, 2011 at 23:29, Mark F. Adams <mark.adams at columbia.edu>wrote:
> An alternative to a virtual function is changing the hash table code:
> #define HASH_FACT 79943
> #define HASHT(ta,x) ((unsigned long)((HASH_FACT*(unsigned
> long)x)%ta->tablesize))
> and make HASH_FACT a variable. Set HASH_FACT to 1 if you want an array
> (and thus the index (x) is less than the table size tablesize). The index x
> is one based so the hash function should modified:
> long)(x-1))%ta->tablesize))
This is an interesting idea. Storage is still double the array, but I think
the cases where we want a dense array will generally not be so space
limited.
As for very bad behavior shown earlier, I wonder if those problems were
causing clustering of some sort so that the linear probing was having
problems. It would be interesting for diagnostic purposes to record
collision statistics.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110919/cb523586/attachment.html>
