[petsc-dev] Failure converting MPIBAIJ -> MPIAIJ
    Hong Zhang
    hzhang at mcs.anl.gov
    Mon Sep 19 15:20:38 CDT 2011
I pushed fix of MatConvert_xxx_xxx() to petsc-3.2, and merged to petsc-dev.
Let me know if you still get problem.
Hong
On Mon, Sep 19, 2011 at 10:17 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Sep 19, 2011, at 10:12 AM, Lisandro Dalcin wrote:
>> On 19 September 2011 11:06, Hong Zhang <hzhang at mcs.anl.gov> wrote:
>>> Lisandro :
>>> I cannot reproduce this error using a C code (ex160.c attached).
>> You have to explicitly ask for MATMPIBAIJ, change the MatSetType like below:
>>  ierr = MatSetType(A,MATMPIBAIJ);CHKERRQ(ierr);
>> With that change, you C code fails exactly the same as my Python code.
>> I knot this makes little sense (I mean, creating MPIBAIJ on a single
>> process), and perhaps fixing this issue is not worth it,
>   It is worth fixing and must be fixed. If MPIBAIJ matrices don't work in the trivial case one cannot expect them to work in the parallel case.
>   Thanks for bringing this up.
>    Barry
>> but I wanted
>> to let you know about the error. I think making MPIXXX types work in a
>> single process is an extra sanity check for the code.
>>> Why MatConvert_MPIBAIJ_MPIAIJ()  is being called for sequential matrix?
>> As I said, this is because I'm forcibly creating MPIBAIJ on a single process.
>> Lisandro Dalcin
>> CIMEC (INTEC/CONICET-UNL)
>> Predio CONICET-Santa Fe
>> Colectora RN 168 Km 472, Paraje El Pozo
>> 3000 Santa Fe, Argentina
>> Tel: +54-342-4511594 (ext 1011)
>> Tel/Fax: +54-342-4511169
