[petsc-dev] Failure converting MPIBAIJ -> MPIAIJ
Lisandro Dalcin
dalcinl at gmail.com
Mon Sep 19 10:12:08 CDT 2011
On 19 September 2011 11:06, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Lisandro :
> I cannot reproduce this error using a C code (ex160.c attached).
You have to explicitly ask for MATMPIBAIJ, change the MatSetType like below:
ierr = MatSetType(A,MATMPIBAIJ);CHKERRQ(ierr);
With that change, you C code fails exactly the same as my Python code.
I knot this makes little sense (I mean, creating MPIBAIJ on a single
process), and perhaps fixing this issue is not worth it, but I wanted
to let you know about the error. I think making MPIXXX types work in a
single process is an extra sanity check for the code.
> Why MatConvert_MPIBAIJ_MPIAIJ() is being called for sequential matrix?
As I said, this is because I'm forcibly creating MPIBAIJ on a single process.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
