[petsc-dev] [petsc-maint #87339] Re: ex19 on GPU
Barry Smith
bsmith at mcs.anl.gov
Sun Sep 18 11:56:59 CDT 2011
Ok, the copy up and down are not a problem.
Except for VecMAXPY() the vector operations are terrible (like they are not using the GPU, but they must be?) The MatMult() must be GPU because it is pretty good 2779???
Does someone else have access to a similar system and can they run the exact same test to see what numbers they get? Satish, could you on breadboard? Maybe on Magellion :-)
Barry
VecDot 2 1.0 1.7049e-03 1.0 1.60e+05 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 94
VecMDot 2024 1.0 8.6273e+00 1.0 2.54e+09 1.0 0.0e+00 0.0e+00 0.0e+00 50 29 0 0 0 66 29 0 0 0 295
VecNorm 2096 1.0 1.5544e+00 1.0 1.68e+08 1.0 0.0e+00 0.0e+00 0.0e+00 9 2 0 0 0 12 2 0 0 0 108
VecScale 2092 1.0 3.7774e-01 1.0 8.37e+07 1.0 0.0e+00 0.0e+00 0.0e+00 2 1 0 0 0 3 1 0 0 0 222
VecCopy 2072 1.0 3.8258e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 3 0 0 0 0 0
VecSet 70 1.0 1.3119e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecAXPY 108 1.0 4.7407e-02 1.0 8.64e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 182
VecWAXPY 68 1.0 1.2545e-02 1.0 2.72e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 217
VecMAXPY 2092 1.0 6.4464e-01 1.0 2.71e+09 1.0 0.0e+00 0.0e+00 0.0e+00 4 31 0 0 0 5 31 0 0 0 4198
VecScatterBegin 5 1.0 1.5609e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecReduceArith 2 1.0 3.8650e-03 1.0 1.60e+05 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 41
VecReduceComm 1 1.0 0.0000e+00 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecCUSPCopyTo 49 1.0 3.0950e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
VecCUSPCopyFrom 44 1.0 2.0876e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
SNESSolve 1 1.0 1.3044e+01 1.0 8.87e+09 1.0 0.0e+00 0.0e+00 0.0e+00 75100 0 0 0 100100 0 0 0 680
SNESLineSearch 2 1.0 1.1921e-02 1.0 5.49e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 461
SNESFunctionEval 3 1.0 2.7192e-03 1.0 2.52e+06 1.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 927
SNESJacobianEval 2 1.0 2.0424e-01 1.0 3.85e+07 1.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 2 0 0 0 0 188
KSPGMRESOrthog 2024 1.0 9.2522e+00 1.0 5.09e+09 1.0 0.0e+00 0.0e+00 0.0e+00 53 57 0 0 0 71 57 0 0 0 550
KSPSetup 2 1.0 5.1975e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
KSPSolve 2 1.0 1.2819e+01 1.0 8.83e+09 1.0 0.0e+00 0.0e+00 0.0e+00 74 99 0 0 0 98 99 0 0 0 689
PCSetUp 2 1.0 9.5367e-07 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
PCApply 2024 1.0 3.8054e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 2 0 0 0 0 3 0 0 0 0 0
MatMult 2092 1.0 1.1950e+00 1.0 3.32e+09 1.0 0.0e+00 0.0e+00 0.0e+00 7 37 0 0 0 9 37 0 0 0 2779
On Sep 18, 2011, at 10:29 AM, Shiyuan wrote:
> On Sat, Sep 17, 2011 at 10:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Run the first one with -da_vec_type seqcusp and -da_mat_type seqaijcusp
> > VecScatterBegin 2097 1.0 1.0270e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 5 0 0 0 0 7 0 0 0 0 0
> > VecCUSPCopyTo 2140 1.0 2.4991e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 2 0 0 0 0 0
> > VecCUSPCopyFrom 2135 1.0 1.0437e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 5 0 0 0 0 7 0 0 0 0 0
> Why is it doing all these vector copy ups and downs? It is run on one process it shouldn't be doing more than a handful total.
> Barry
> ./ex19 -da_vec_type seqcusp -da_mat_type seqaijcusp -pc_type none -dmmg_nlevels 1 -da_grid_x 100 -da_grid_y 100 -log_summary -mat_no_inode -preload off -cusp_synchronize -cuda_set_device 0 | tee ex19p2.txt
> Summary of Stages: ----- Time ------ ----- Flops ----- --- Messages --- -- Message Lengths -- -- Reductions --
> Avg %Total Avg %Total counts %Total Avg %Total counts %Total
> 0: Main Stage: 4.2393e+00 24.4% 0.0000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
> 1: SetUp: 4.9079e-02 0.3% 0.0000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
> 2: Solve: 1.3071e+01 75.3% 8.8712e+09 100.0% 0.000e+00 0.0% 0.000e+00 0.0% 0.000e+00 0.0%
> The complete log is attached. Thanks.
> <ex19p2.txt>
