[petsc-dev] How do you get RIchardson?
Fri Sep 16 16:38:06 CDT 2011
On Fri, Sep 16, 2011 at 23:21, Matthew Knepley <knepley at gmail.com> wrote:
> it still converges, conditionally to the same solution as exact
>> newton. Variations for A yield different rates of convergence. When
>> A=1, you get the classical Picard iteration that Matt mentioned (?).
> Not even close.
>From Barry's description at the top of this thread:
 x^{n+1}   = x^{n}  - lambda F(x^{n})
This looks oddly similar to
 x^{n+1}   = x^{n}  - J(x^n)^{-1} F(x^{n})
I wonder where I've seen that before.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110916/ad324b29/attachment.html>
