[petsc-dev] How do you get RIchardson?
    Matthew Knepley
    knepley at gmail.com
    Fri Sep 16 08:33:15 CDT 2011
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/387e672db72a
These are cite Picard for this method:
 http://math.fullerton.edu/mathews/n2003/picarditerationmod.html
 http://cdsweb.cern.ch/record/419580/files/ext-2000-010.pdf
http://books.google.com/books/about/Computational_solution_of_nonlinear_oper.html?id=dexQAAAAMAAJ
http://books.google.com/books?id=BVkbypnD0yUC&pg=PA87&lpg=PA87&dq=Terence+tao+picard&source=bl&ots=VQOpQbFsyn&sig=b-KdPdTXtenRi-dBPsLfdhHcPpY&hl=en&ei=1U9zTv2uFungiAKouuWzAg&sa=X&oi=book_result&ct=result&resnum=7&ved=0CD4Q6AEwBg#v=onepage&q&f=false
Richardson is specifically for linear equations I thought.
    Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110916/0baf5325/attachment.html>
