[petsc-dev] Comments about PThreads
Jose E. Roman jroman at dsic.upv.es
Wed Sep 14 10:11:22 CDT 2011
I have been doing some tests --with-pthreadclasses. I use
$ ./ex12 -n 250 -m 250
(in $PETSC_DIR/src/ksp/ksp/examples/tutorials)
1) I tried with -vec_type pthread as explained in the instructions in features/threads.html
This had a noticeable effect on the run time. However, in another system the execution time did not change, and I realized that it was necessary to also add: -thread_max 2 -main. Question: should these always be used? what is the meaning of -main?
2) I thought adding -mat_type aijpthread would yield even better timings, but the response time was the same. Then I noticed that -mat_view_info showed this:
Matrix Object: 1 MPI processes
  type: seqaij
  rows=62500, cols=62500
so I guess -mat_type aijpthread is not having any effect.
3) I understand that this is still in a very initial stage. However, I think that in order to be usable it is necessary to add MatGetVecs_SeqAIJPThreads (similarly to CUSP). For instance, in SLEPc users normally do not pass vectors but just matrices, and the vectors are created with MatGetVecs (no VecSetFromOptions).
Jose
