[petsc-dev] Stokes flow code PETSC
    Jed Brown
    jedbrown at mcs.anl.gov
    Mon Sep 12 10:37:55 CDT 2011
On Mon, Sep 12, 2011 at 17:20, Jie Chen <jiechen at mcs.anl.gov> wrote:
> One case though, that I think it would be more convenient if the options
> specified in the file are overridden by command line options is, when people
> want to tune parameters. The varying parameters are better changed in
> command line than in the options file. In the case that for some reason the
> file already specifies the parameters, I would like to see them overridden
> by command line options.
I agree about usually wanting the command line to have priority. The
question is
1. Is it any hardship to always put -options_file first in the command line
so that later args always override it?
2. Is it more confusing to have -options_file parsed first, or to have all
options parsed in the sequence where -options_file is effectively an
"include"?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110912/e6aa99ed/attachment.html>
