[petsc-dev] Qt Creator
Wed Sep 7 07:25:01 CDT 2011
On Sep 7, 2011, at 5:31 AM, Jed Brown wrote:
> I just saw this addition
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/bd0a66b60832
> Qt Creator supports CMake, so you can just point it at a PETSC_ARCH without any special configuration. Is there a reason to prefer this manual project file setup?
   Yes, because it doesn't require CMake :-).
    You can add this information to the users manual above the "manual" approach if you like.
    Barry
