[petsc-dev] Dev release GPU solvers
Matthew Knepley
knepley at gmail.com
Tue Sep 6 11:27:50 CDT 2011
On Tue, Sep 6, 2011 at 11:25 AM, Randall Mackie <rlmackie862 at gmail.com>wrote:
> On Sep 6, 2011, at 9:16 AM, Matthew Knepley wrote:
> On Tue, Sep 6, 2011 at 11:12 AM, Randall Mackie <rlmackie862 at gmail.com>wrote:
>> On Sep 6, 2011, at 9:08 AM, Barry Smith wrote:
>> > On Sep 6, 2011, at 10:59 AM, Daniel Lowell wrote:
>> >> On this page: http://www.mcs.anl.gov/petsc/petsc-as/features/gpus.html
>> >> It states: "All of the Krylov methods except KSPIBCGS run on the GPU."
>> >> I actually could only find ksp/pc/bicgstabcusp for any ksp
>> implementation on the GPU.
>> > Daniel,
>> > All the vector operations and the matrix-vector product used by the
>> Krylov methods implemented in PETSc (except KSPIBCGS) run on the GPU without
>> copying up or down vector or matrix values, in the same way as
>> ksp/pc/bicgstabcusp does, hence we say they run on the GPU. In fact, in our
>> tests our BiGCStab runs just as fast as the Nvidia CUSP code
>> ksp/pc/bicgstabcusp.
>> > In other words, higher level algorithms such as Krylov methods and
>> Newton methods do not need to be "written for the GPU", so long as the
>> kernel operations run on the GPU.
>> > Barry
>> Barry,
>> But is this still only for real data types? Last time I checked, earlier
>> this year, complex valued data were not
>> supported under PETSc, even though complex data types are supported in
>> CUSP.
> I have not tried, but I do not understand why it would not work. We just
> use PetscScalar. Can you send
> the problem you found?
> Matt
> Matt,
> Here is the message that I received earlier this year, but I never did have
> time to follow up on it then:
Ah, so I would characterize this as "CUSP does not work with std::complex",
which is a big problem.
Matt
> *From: *Barry Smith <bsmith at mcs.anl.gov>
> *Date: *May 24, 2011 5:04:51 AM PDT
> *To: *petsc-maint at mcs.anl.gov, Victor Minden <victorminden at gmail.com>
> *Cc: *Randall Mackie <rlmackie862 at gmail.com>
> *Subject: **Re: [petsc-maint #71751] error during compile*
> Victor,
> Thanks for the info. I've forgotten about the blas.
> Randall,
> Looks like it is not so trivial as I had made it out to be. Perhaps if
> you ask on petsc-dev at mcs.anl.gov there may be people who want this also
> and are willing to share the work?
> Barry
> On May 23, 2011, at 6:06 PM, Victor Minden wrote:
> Barry,
> Currently there should be two things going on--one is that some of the
> CUBLAS routines used for basic vector operations (which we've been moving
> away from) have 4 different forms depending on single/double and
> real/complex--currently those that we still use are hard-coded as real and
> #ifdeffed to be single/double, and I haven't looked in depth but I think
> those are the errors that Randy sent.
> Those should be pretty quick to change, but they won't make complex work,
> because once you get past veccusp.cu there are a bunch more errors in the
> cusp matrix routines which work with complex if you use the relatively new
> (Oct? Dec?) cusp complex type that they've added to the cusp library. So,
> we need to make the GPU routines work with the standard complex type or we
> need to convert all the GPU code to use the cusp type. I don't know how
> much work this is.
> As it stands, I'm just starting my internship this week so I probably won't
> be able to look at this in-depth until the weekend, just FYI.
> Cheers,
> Victor
> Victor L. Minden
> Tufts University
> School of Engineering
> Class of 2012
>> Randy
>> >> CUSP does have everything mentioned in the above PETSc link:
>> http://code.google.com/p/cusp-library/wiki/QuickStartGuide#Iterative_Solvers
>> >> However I don't see where any of it is implemented in the latest Dev
>> release, Krylov solvers or preconditioners.
>> >> Can anyone clear this up for me?
>> >> Thanks,
>> >> Daniel Lowell
> experiments lead.
> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110906/e4d4b895/attachment.html>
