[petsc-dev] rebase question
Jed Brown
jedbrown at mcs.anl.gov
Mon Sep 5 02:58:29 CDT 2011
On Mon, Sep 5, 2011 at 07:56, Satish Balay <balay at mcs.anl.gov> wrote:
> Just want to point out that the same thing should happen with 'hg
> update' - or with the alternative workflow to 'hg pull --rebase' i.e
> 'hg pull; hg merge; hg commit'
> i.e in all the above cases - the working files get updated by
> mercurial underneath emacs.
Suppose you have a repository like this
@ changeset: 2:c4d14c7899e5
| tag: tip
| parent: 0:c2e4f2b285da
| user: Jed Brown <jed at 59A2.org>
| date: Mon Sep 05 09:39:37 2011 +0200
| summary: mine
| o changeset: 1:3a3076850a53
|/ user: Jed Brown <jed at 59A2.org>
| date: Mon Sep 05 09:38:05 2011 +0200
| summary: upstream
o changeset: 0:c2e4f2b285da
date: Mon Sep 05 09:37:40 2011 +0200
summary: initial
and suppose r2 makes a modification to a file present in r0 that was not
changed by r1. Then we could ask for rebase to not update mtime for this
file. This is not the case:
$ stat a
File: `a'
Size: 8 Blocks: 8 IO Block: 4096 regular file
Device: 806h/2054d Inode: 1439054 Links: 1
Access: (0644/-rw-r--r--) Uid: ( 1000/ jed) Gid: ( 100/ users)
Access: 2011-09-05 09:43:07.743270567 +0200
Modify: 2011-09-05 09:42:53.809936424 +0200
Change: 2011-09-05 09:42:53.809936424 +0200
Birth: -
$ hg rebase -s 2 -d 1
saved backup bundle to /tmp/repo-hg/.hg/strip-backup/a00050fc43a7-backup.hg
$ stat a
File: `a'
Access: 2011-09-05 09:43:18.689937868 +0200
Modify: 2011-09-05 09:43:18.689937868 +0200
Change: 2011-09-05 09:43:18.689937868 +0200
Birth: -
If instead we merge, mtime is not updated:
$ stat a
File: `a'
Access: 2011-09-05 09:45:52.003280085 +0200
Modify: 2011-09-05 09:45:49.719946619 +0200
Change: 2011-09-05 09:45:49.719946619 +0200
Birth: -
$ hg merge 1
1 files updated, 0 files merged, 0 files removed, 0 files unresolved
(branch merge, don't forget to commit)
$ hg commit -m merge
$ stat a
File: `a'
Birth: -
Sean, I was wrong in our conversation in the parking lot. Git behaves the
same way:
$ echo aaa > a
repo-git$ git add a
repo-git$ git commit -m initial
[master (root-commit) ec625c5] initial
1 files changed, 1 insertions(+), 0 deletions(-)
create mode 100644 a
master repo-git$ echo bbb > b
repo-git$ git add b
repo-git$ git commit -m upstream
[master 740d68c] upstream
create mode 100644 b
repo-git$ git checkout -b mine HEAD^
Switched to a new branch 'mine'
repo-git$ echo ccc >> a
repo-git$ git commit -am mine
[mine 6f4c2d9] mine
$ git log master
commit 740d68ca145ec28b3cf936d65827a64fe6a6682f
Author: Jed Brown <jed at 59A2.org>
Date: Mon Sep 5 09:47:32 2011 +0200
upstream
commit ec625c5bbc19b13ded14643a9f79cd0e99829313
Date: Mon Sep 5 09:47:21 2011 +0200
initial
repo-git$ git log
commit 6f4c2d9d5a8a632233fc0da0139e8d4ed52c6b23
Date: Mon Sep 5 09:48:11 2011 +0200
mine
initial
repo-git$ stat a
File: `a'
Device: 806h/2054d Inode: 1439111 Links: 1
Access: 2011-09-05 09:52:46.199970753 +0200
Modify: 2011-09-05 09:52:06.809968470 +0200
Change: 2011-09-05 09:52:06.809968470 +0200
Birth: -
$ git rebase master
First, rewinding head to replay your work on top of it...
Applying: mine
$ stat a
File: `a'
Access: 2011-09-05 09:53:00.499971581 +0200
Modify: 2011-09-05 09:53:00.496638247 +0200
Change: 2011-09-05 09:53:00.496638247 +0200
Birth: -
If you do the rebasing with an Emacs mode, it should track which files are
changed and update them accordingly.
If you don't want to set global-auto-revert-mode, you can do something like
this
(global-set-key (kbd "C-x T") '(lambda () (interactive) (revert-buffer nil
t))) ; revert without query
to reduce the interruption caused by reverting files. It all depends how
tightly you like buffers to be associated with files.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110905/50e805ea/attachment.html>
