[petsc-dev] fortran binding for TSConvergedReason
Satish Balay
balay at mcs.anl.gov
Thu Oct 27 16:15:16 CDT 2011
Yes - next patch update to petsc-3.2 should have this file correctly
generated..
In the meantime - you can use the updated tsf.c [attached]
Satish
On Thu, 27 Oct 2011, Blaise Bourdin wrote:
> It works, great.
> Any chance these changes will make their way in 3.2?
> Blaise
> On Oct 27, 2011, at 4:04 PM, Jed Brown wrote:
> > On Thu, Oct 27, 2011 at 15:00, Blaise Bourdin <bourdin at lsu.edu> wrote:
> > OK, so this time, I deleted externalpackages/sow* externalpackages/_d_sow* , $PETSC_ARCH, reconfigured and rebuild, but the fortran binding is unchanged. I even deleted it and ran make allfortranstubs, but I still get the same error.
> > Satish, the tarball doesn't seem to have updated.
> > Blaise, I added man pages and Fortran bindings for the enum values. I updated ex1f.F to check the reason and it works (with hand-modified sowing).
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111027/edea328a/attachment.c>
