[petsc-dev] Problem mixing sieve and TS
Jed Brown
jedbrown at mcs.anl.gov
Thu Oct 27 00:25:13 CDT 2011
On Wed, Oct 26, 2011 at 23:09, Paul Sicsic <paul.sicsic at polytechnique.edu>wrote:
> - The dot variable is still Nan when trying to compute the IFunction.
> - These options seem to still be giving a shift that is infinity when
> computing the IJacobian. (In step 0 here)
> Yeah, this is the problem, but I can't reproduce it for other problems.
With these symptoms, I would expect memory corruption or a build/link error.
Can you confirm that the examples run correctly?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111026/24357ba5/attachment.html>
