[petsc-dev] TS monitoring at fixed times?
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Oct 23 14:26:43 CDT 2011
    It would be nice to be able to run the TS monitors so that they are called at fixed "times" instead of just fixed "timesteps". For example, save to a file the solution at each .1 seconds.  This would be useful for doing grid convergence studies, parameter studies, etc.
     Presumably this could be done by having a TS monitor check if it has passed the next "time-point" and then interpolate the solution back (or something back) to that point and then (somehow) call the regular TS monitor that plots the solution, saves it to a file, etc.
    Thoughts? Difficulties?
     Barry
