[petsc-dev] need for C++ streams versions of routines with output?
Barry Smith
bsmith at mcs.anl.gov
Fri Oct 21 08:35:13 CDT 2011
Is there really a need for PetscTraceBackErrorHandlerCxx() that uses C++ streams for output instead of C IO but otherwise looks very similar to PetscTraceBackErrorHandler()? It seems like a gross duplication of code (including specific error message stuff that will get out of sync between the two versions very quickly.) It, at least needs a Developers Note: in the manual page saying why it exists when it has this troubling code duplication.
Barry
