[petsc-dev] VecNestSetSubVec for VecNest.
Vijay S. Mahadevan
vijay.m at gmail.com
Mon Oct 17 21:29:15 CDT 2011
http://www.mail-archive.com/libmesh-devel@lists.sourceforge.net/msg02100.html ??
On Mon, Oct 17, 2011 at 9:25 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> We discussed Vec local/global semantics on the libmesh list a year ago or
> more. I didn't think there was a failing in the current system, but libmesh
> imposes some stricter consistency on local vectors, which sometimes causes
> unnecessary communication. I don't recall all the details, but we can dig up
> the thread.
> On Oct 17, 2011 9:17 PM, "Vijay S. Mahadevan" <vijay.m at gmail.com> wrote:
>> > I would not try to simultaneously change the distribution of the Vec.
>> > That's
>> > what VecScatter is for. VecConvert() would keep the same distribution
>> > and
>> > give you back a semantically identical vector of a different type.
>> Well, I implied changing the parallel layout because of the code I've
>> seen in say libMesh and other packages using PETSc. Their idea of
>> localize() is often to convert a MPI vector to a locally serial vector
>> with/without ghost nodes. I see your point on using VecScatter and so
>> VECSEQ can still be disallowed but some form of Ghosted parallel
>> vector conversion would still be useful.
>> On Mon, Oct 17, 2011 at 9:00 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> > On Mon, Oct 17, 2011 at 20:55, Vijay S. Mahadevan <vijay.m at gmail.com>
>> > wrote:
>> >> Actually, that is quite consistent in philosophy to the merge
>> >> operation I'm trying to perform. SEQ->MPI might still be an invalid
>> >> operation for Vec though. Perhaps with a PETSC_DECIDE for local, it
>> >> still could be relevant ? You can definitely specialize this for
>> >> MPI->SEQ and Nest Vectors with a new VecReuse enum with relevant
>> >> names.
>> > That's
>> > and
