[petsc-dev] Moving from BG/L to BG/P
Kevin.Buckley at ecs.vuw.ac.nz
Sun Oct 16 23:12:50 CDT 2011
> Just to clarify - petsc-bgl-tools were useful for the first generation
> of BlueGene [bg/l] with the first generation of software stack - where
> mpixlc/mpixlf77/mpixlf90 wrappers to use IBM compilers with MPI on
> these machines were absent.
> Subsequent machines [bg/p] and perhaps software stack update to bg/l
> do provide proper mpixlc/mpixlf77/mpixlf90 warppers. [so
> petsc-bgl-tools isn't needed anymore]
> As Jed suggested - use config/examples/arch-bgp-ibm-opt.py - modify it
> appropriately for the externalpackages requred - and run it.
> Satish
Thanks to both of you, for those pointers and clarification.
Initially, I was thinking that the researcher would want to
stick with the 3.0 series so had not looked at the 3.2 sources,
and hence not finding the
mentioned, however, we are going to move with the times.
I thus altered the external package options to match those of the
3.0.0-p9 build in a copy of that file and ran it.
I get some odd output when trying to pull in the latest
SuperLU, which I grabbed from ANL
'--download-superlu=/path/to/superlu_4.0-March_7_2010.tar.gz',
It starts to compile but then fails with this output
mpixlc_r -O3 -qarch=450d -qtune=450 -qmaxmem=-1 -DNoChange
-DUSE_VENDOR_BLAS -c ilu_heap_relax_snode.c
-DUSE_VENDOR_BLAS -c mark_relax.c
c mc64ad.f
c mc21.f
make[1]: c: Command not found
Looking at
externalpackages/SuperLU_4.0/SRC/Makefile
suggests to me that the default rule for
.f.o:
$(FORTRAN) $(FFLAGS) -c $<
isn't seeing the $(FORTRAN) or $(FFLAGS) expanded.
Along the right lines ? Or missed something obvious ?
Kevin
Kevin M. Buckley Room: CO327
School of Engineering and Phone: +64 4 463 5971
Computer Science
Victoria University of Wellington
New Zealand
