[petsc-dev] TS alpha parameter for preconditioner function
Ben Dudson
benjamin.dudson at york.ac.uk
Sat Oct 15 08:08:24 CDT 2011
Hello
I'm using the petsc-dev TS system to solve a system
u' = F(u)
and would like to supply my own preconditioner to the KSP linear solver
inside the SNES nonlinear solver. The Jacobian of the system is difficult
to evaluate, so I would like to remain matrix-free. I have however got an
approximate inverse operator of the linear system being solved by KSP:
(I - alpha*J)
In SUNDIALS it's possible to supply a preconditioner function which is then
called passing the system state, vector to be preconditioned, and the alpha
parameter. To do this in PETSc, should I define a MatShell or PCShell, and
is there a way to get alpha from the TS?
Thanks in advance
Ben Dudson
Department of Physics
University of York
