[petsc-dev] [petsc-maint #89809] 3D DMDAs in petsc-3.2
Barry Smith
bsmith at mcs.anl.gov
Tue Oct 11 17:40:12 CDT 2011
Yup, push to 3.2 repository please.
Thanks
Barry
On Oct 11, 2011, at 5:22 PM, Ethan Coon wrote:
> Attached is a bug fix (wasn't sure if it should just get pushed back to
> the repo or not).
> The /* 2d case */ stuff should only take affect when z-periodic, P=1 and
> s>1 (but there was stupidity in the if statement that caused it to get
> used in ex38, where P != 1). All it does is flatten all z-communication
> to think it is a stencil size of 1, which keeps the "from" index within
> the global-numbering range (i.e. >=0, <M*N*P). Normally this case would
> break -- if s > P, then logically the s'th ghost cell in the z-direction
> should loop through the mesh a second time. There was a check to make
> sure that s <= {x,y,z} to make sure that all ghost cells sit on the
> nearest neighbor-process. In the case where P=1, the number of procs in
> z is obviously 1, and we can simply copy that value to all ghost cells
> in the z-direction.
> While it should be the case that the only time a "from" index is out of
> bounds for the global numbering is during this special case, I added an
> extra flag to make sure we were in the special case, to avoid masking
> any future bugs which would otherwise show up in the index set creation.
> Ethan
> On Sun, 2011-10-09 at 22:54 -0500, Barry Smith wrote:
>> Jed,
>> It appears your some of your many
>> if (s_t >= x*y*z) {s_t = bases[n26] + (i-1)*x_t;} /* 2d case */
>> things are breaking the communication with a stencil width of 2
>> In src/dm/examples/tests/ex38.c in petsc-3.2
>> barry-smiths-macbook-pro:tests barrysmith$ petscmpiexec -n 2 ./ex38
>> Vector Object: 1 MPI processes
>> type: seq
>> 0
>> 1
>> 2
>> 3
>> 4
>> 5
>> 6
>> 7
>> 8
>> 9
>> 10
>> 11
>> 112
>> 113
>> 114
>> 115
>> 116
>> 117
>> 112
>> 113
>> 114
>> 115
>> 116
>> 117
>> the second layer of ghost points uses the first layer instead of getting the second layer.
>> Since I don't understand your /* 2d case */ business I leave it to you to fix
>> So either I still have a bug in my test code (always possible) or you've introduced your first bug into PETSc (seems unlikely),
>> Barry
>> On Oct 9, 2011, at 8:09 PM, Jed Brown wrote:
>>> Ex48 uses periodic in y and z and it works.
>>> On Oct 9, 2011 8:08 PM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
>>> Ok 3.1-p8 also fails with the same problems. Likely periodic boundary conditions have never worked in 3d? Yikes this looks bad
>>> Barry
>>> On Oct 9, 2011, at 3:28 PM, Barry Smith wrote:
>>>> I have created a new test example in petsc-3.2 for 3D global to local with periodic boundary conditions and it fails rather completely so whomever introduced all the IXs, IXe stuff into DMSetUp_DA_3d() likely introduced some bugs, or the bugs have always been there and no one has tested it properly.
>>>> For example (with periodicity indicated only in the x direction) one gets:
>>>> barry-smiths-macbook-pro:tests barrysmith$ petscmpiexec -n 2 ./ex38 -da_view -stencil_width 1 | more
>>>> Processor [0] M 2 N 3 P 4 m 1 n 1 p 2 w 1 s 1
>>>> X range of indices: 0 2, Y range of indices: 0 3, Z range of indices: 0 2
>>>> Processor [1] M 2 N 3 P 4 m 1 n 1 p 2 w 1 s 1
>>>> X range of indices: 0 2, Y range of indices: 0 3, Z range of indices: 2 4
>>>> type: seq
>>>> 1
>>>> 0
>>>> 1
>>>> 0
>>>> 3
>>>> 2
>>>> 3
>>>> 2
>>>> 5
>>>> 4
>>>> 5
>>>> 4
>>>> 7
>>>> 6
>>>> 7
>>>> 6
>>>> 9
>>>> 8
>>>> 9
>>>> 8
>>>> 11
>>>> 10
>>>> 11
>>>> 10
>>>> -1
>>>> 112
>>>> 113
>>>> -1
>>>> -1
>>>> 114
>>>> 115
>>>> -1
>>>> -1
>>>> 116
>>>> 117
>>>> -1
>>>> so it is not properly handling the periodicity on the "ghost plane" brought over from the rank 1 process to the rank 0.
>>>> Note this happens also with a stencil width of 1, so it is not just a question of not handling the stencil width correctly.
>>>> Barry
>>>> On Oct 9, 2011, at 1:32 PM, Richard Katz wrote:
>>>>> Here's how I set up the problem:
>>>>> ierr = DMDACreate3d(user->comm,DMDA_BOUNDARY_PERIODIC,DMDA_BOUNDARY_PERIODIC,DMDA_BOUNDARY_NONE,
>>>>> DMDA_STENCIL_BOX,p->Ni,p->Nj,p->Nk,1,1,PETSC_DECIDE,
>>>>> (PetscInt)(sizeof(SolVel3D)/sizeof(PetscReal)),2,
>>>>> PETSC_NULL,PETSC_NULL,PETSC_NULL,&user->dav);CHKERRQ(ierr);
>>>>> ierr = DMCreateGlobalVector(user->dav,&user->v);CHKERRQ(ierr);
>>>>> ierr = DMCreateGlobalVector(user->daa,&user->an);CHKERRQ(ierr);
>>>>> ierr = VecDuplicate(user->v,&user->vo);CHKERRQ(ierr);
>>>>> ierr = VecDuplicate(user->v,&user->vm);CHKERRQ(ierr);
>>>>> ierr = VecDuplicate(user->v,&user->rv);CHKERRQ(ierr);
>>>>> ierr = VecDuplicate(user->an,&user->ano);CHKERRQ(ierr);
>>>>> ierr = SNESCreate(user->comm,&user->snes);CHKERRQ(ierr);
>>>>> if (D2(p)) { ierr = SNESSetFunction(user->snes,user->rv,FormResidual_v2d,user);CHKERRQ(ierr); }
>>>>> else { ierr = SNESSetFunction(user->snes,user->rv,FormResidual_v3d,user);CHKERRQ(ierr); }
>>>>> ierr = DMGetColoring(user->dav,IS_COLORING_GLOBAL,MATAIJ,&iscoloring);
>>>>> ierr = DMGetMatrix(user->dav,MATAIJ,&user->Jv);CHKERRQ(ierr);
>>>>> ierr = MatFDColoringCreate(user->Jv,iscoloring,&user->mfdcv);
>>>>> ierr = MatFDColoringSetFromOptions(user->mfdcv);CHKERRQ(ierr);
>>>>> if (D2(p)) { ierr = MatFDColoringSetFunction(user->mfdcv,(PetscErrorCode(*)(void))FormResidual_v2d,user); }
>>>>> else { ierr = MatFDColoringSetFunction(user->mfdcv,(PetscErrorCode(*)(void))FormResidual_v3d,user); }
>>>>> ierr = SNESSetJacobian(user->snes,user->Jv,user->Jv,SNESDefaultComputeJacobianColor,user->mfdcv);
>>>>> ierr = ISColoringDestroy(&iscoloring);
>>>>> ierr = SNESSetOptionsPrefix(user->snes,"PV_");CHKERRQ(ierr);
>>>>> ierr = SNESSetFromOptions(user->snes);CHKERRQ(ierr);
>>>>> D2(p) is a macro that returns 1 if the problem is 2D, and 0 if 3D.
>>>>> Rich
>>>>> On 9 Oct 2011, at 19:30, Barry Smith wrote:
>>>>>> box stencil or star stencil?
>>>>>> On Oct 9, 2011, at 1:26 PM, Richard Katz wrote:
>>>>>>> On 9 Oct 2011, at 19:24, Barry Smith wrote:
>>>>>>>> To clarify: With this build valgrind generates no messages at all?
>>>>>>> That's correct.
>>>>>>> [magmox:test]$ $PETSC_DIR/bin/petscmpiexec -valgrind -n 2 ../porbandsim -nd 3 -alpha 2 -theta 45 -output_file test2
>>>>>>> --94613-- run: /usr/bin/dsymutil "../porbandsim"
>>>>>>> --94612-- run: /usr/bin/dsymutil "../porbandsim"
>>>>>>> --------------porbandsim: Sun Oct 9 17:24:24 2011---------------
>>>>>>> Processes: 2, DOFs/Process: 2800
>>>>>>> #PETSc Option Table entries:
>>>>>>> -PV_snes_converged_reason
>>>>>>> -PV_snes_monitor
>>>>>>> -alpha 2
>>>>>>> -ksp_gmres_restart 150
>>>>>>> -nd 3
>>>>>>> -output_file test2
>>>>>>> -snes_converged_reason
>>>>>>> -snes_monitor
>>>>>>> -theta 45
>>>>>>> #End of PETSc Option Table entries
>>>>>>> PetscBag Object: ParameterBag params for porosity band simulation
>>>>>>> takei = TRUE; Use Takei & Holztman (2009) viscosity (T/F)
>>>>>>> hperm = FALSE; Use harmonic mean for computing permeability (T/F)
>>>>>>> lambda = 27; Porosity-weakening exponent in shear viscosity, dim'less
>>>>>>> R = 0.57735; Ratio compaction length to domain height, dim'less
>>>>>>> sigma_sat = 1; Saturation stress-difference for anisotropy, dim'less
>>>>>>> n = 3; Exponent in porosity--permeability relationship, dim'less
>>>>>>> phi0 = 0.1; Initial porosity, dim'less
>>>>>>> phi1 = 0.01; Amplitude of porosity perturbation, dim'less
>>>>>>> theta = 45; Fixed anisotropy angle, degrees (-1234567 indicates dynamic)
>>>>>>> alpha = 2; Fixed anisotropy magnitude, 0<=alpha<=2 (-1234567 indicates dynamic)
>>>>>>> viscratio = 1.66667; Ratio of bulk to shear viscosity at phi=phi0, dim'less
>>>>>>> nsig = 1; Exponent in stress--strain rate relationship, dim'less
>>>>>>> init_harmonic = FALSE; Use harmonic perturbation as IC (T/F)
>>>>>>> input_file = null; Name base for input porosity file
>>>>>>> test = FALSE; Just load parameters and then exit
>>>>>>> output_file = test2; Name base for output files
>>>>>>> output_all = FALSE; Make output after each time-step (T/F)
>>>>>>> output_err = TRUE; Make output after failed time-step (T/F)
>>>>>>> output_aux = TRUE; Output auxilliary fields (T/F)
>>>>>>> converged = TRUE; Indicates whether a time-step converged (NO SET)
>>>>>>> nb = 2; Number of buffer rows at top and bottom of domain
>>>>>>> ns = 1000000; Maximum number of time-steps
>>>>>>> nits = 1; Number of Picard iterations
>>>>>>> nplot = 0; Output counter
>>>>>>> advect = 1; Advection scheme: 0=FV, 1=Fromm, 2=TVD
>>>>>>> time = 0; Time at current step, dim'less
>>>>>>> cfl = 0.5; Courant-Friedrichs-Lewy number, dim'less
>>>>>>> tmax = 20; Maximimum simulated time, dim'less
>>>>>>> tout = 0.05; Output interval, dim'less
>>>>>>> nd = 3; Number of spatial dimensions, 2 or 3
>>>>>>> ni = 20; Grid points in x-direction (shear-direction, periodic)
>>>>>>> nj = 5; Grid points in y-direction (cross-direction, periodic)
>>>>>>> nk = 14; Grid points in z-direction, incl buffer points
>>>>>>> -------------------------END PARAM REPORT------------------------
>>>>>>> Continuation in lambda for initial condition
>>>>>>> 0 SNES Function norm 2.512586736188e+01
>>>>>>> 1 SNES Function norm 2.149396609776e-03
>>>>>>> 2 SNES Function norm 1.863405745330e-08
>>>>>>> Nonlinear solve converged due to CONVERGED_FNORM_ABS
>>>>>>> Solved with lambda = 1.0 in 205.35 seconds
>>>>>>> 0 SNES Function norm 1.874271649438e+00
>>>>>>> 1 SNES Function norm 8.642606950729e-06
>>>>>>> 2 SNES Function norm 7.636114324949e-11
>>>>>>> Solved with lambda = 2.0 in 206.47 seconds
>>>>>>> 0 SNES Function norm 3.748572573117e+00
>>>>>>> 1 SNES Function norm 1.823985563954e-05
>>>>>>> 2 SNES Function norm 1.446658479082e-10
>>>>>>> Solved with lambda = 4.0 in 207.02 seconds
>>>>>>> 0 SNES Function norm 7.498313656718e+00
>>>>>>> 1 SNES Function norm 3.949293531885e-05
>>>>>>> 2 SNES Function norm 3.092503935042e-10
>>>>>>> Solved with lambda = 8.0 in 207.44 seconds
>>>>>>> 0 SNES Function norm 1.500973207738e+01
>>>>>>> 1 SNES Function norm 8.256012403101e-05
>>>>>>> 2 SNES Function norm 6.728525270322e-10
>>>>>>> Solved with lambda = 16.0 in 207.38 seconds
>>>>>>> 0 SNES Function norm 2.066862203903e+01
>>>>>>> 1 SNES Function norm 6.201694512543e-05
>>>>>>> 2 SNES Function norm 5.537777484572e-10
>>>>>>> Solved with lambda = 27.0 in 207.32 seconds
>>>>>>> Generating output file: "test2_0000"
>>>>>>> 0 SNES Function norm 1.914413986104e+01
>>>>>>> 1 SNES Function norm 7.835942994856e-05
>>>>>>> 2 SNES Function norm 2.520454050827e-10
>>>>>>> 0 SNES Function norm 2.038885321297e+01
>>>>>>> 1 SNES Function norm 1.727646593582e-04
>>>>>>> 2 SNES Function norm 1.325429214752e-09
>>>>>>> Stepped to time t = 0.050 in 213.4 seconds
>>>>>>> Generating output file: "test2_0001"
>>>>>>> 0 SNES Function norm 1.592319862889e+01
>>>>>>> 1 SNES Function norm 5.602653646480e-05
>>>>>>> 2 SNES Function norm 2.453571869974e-10
>>>>>>> 0 SNES Function norm 1.321599310609e+01
>>>>>>> 1 SNES Function norm 1.261023473773e-04
>>>>>>> 2 SNES Function norm 1.163959209038e-09
>>>>>>> Stepped to time t = 0.100 in 212.6 seconds
>>>>>>> Generating output file: "test2_0002"
>>>>>>> 0 SNES Function norm 1.422948512067e+01
>>>>>>> 1 SNES Function norm 4.242156538283e-05
>>>>>>> 2 SNES Function norm 1.625303993154e-10
>>>>>>> 0 SNES Function norm 9.675556760630e+00
>>>>>>> 1 SNES Function norm 1.362209365650e-04
>>>>>>> 2 SNES Function norm 1.223382062021e-09
>>>>>>> Stepped to time t = 0.150 in 212.9 seconds
>>>>>>> Generating output file: "test2_0003"
>>>>>>> 0 SNES Function norm 1.307890574732e+01
>>>>>>> 1 SNES Function norm 3.214708350215e-05
>>>>>>> 2 SNES Function norm 1.093103013350e-10
>>>>>>> 0 SNES Function norm 7.636762082099e+00
>>>>>>> 1 SNES Function norm 1.308928801753e-04
>>>>>>> 2 SNES Function norm 1.143217709967e-09
>>>>>>> Stepped to time t = 0.200 in 212.8 seconds
>>>>>>> Generating output file: "test2_0004"
>>>>>>> 0 SNES Function norm 1.216229064046e+01
>>>>>>> 1 SNES Function norm 2.441284335468e-05
>>>>>>> 2 SNES Function norm 7.517551623210e-11
>>>>>>> 0 SNES Function norm 6.371107649815e+00
>>>>>>> 1 SNES Function norm 1.185031269819e-04
>>>>>>> 2 SNES Function norm 1.095566218658e-09
>>>>>>> Stepped to time t = 0.250 in 213.0 seconds
>>>>>>> Generating output file: "test2_0005"
>>>>>>> 0 SNES Function norm 1.136564194223e+01
>>>>>>> 1 SNES Function norm 1.865453423897e-05
>>>>>>> 2 SNES Function norm 5.239501925142e-11
>>>>>>> 0 SNES Function norm 5.520895480607e+00
>>>>>>> 1 SNES Function norm 1.025932275448e-04
>>>>>>> 2 SNES Function norm 1.071648118984e-09
>>>>>>> Stepped to time t = 0.300 in 213.0 seconds
>>>>>>> Generating output file: "test2_0006"
>>>>>>> 0 SNES Function norm 1.064481900239e+01
>>>>>>> 1 SNES Function norm 1.438574893573e-05
>>>>>>> 2 SNES Function norm 3.643963189108e-11
>>>>>>> 0 SNES Function norm 4.905069034291e+00
>>>>>>> 1 SNES Function norm 8.961489700096e-05
>>>>>>> 2 SNES Function norm 1.008198626576e-09
>>>>>>> Stepped to time t = 0.350 in 212.7 seconds
>>>>>>> Generating output file: "test2_0007"
>>>>>>> 0 SNES Function norm 9.981300326125e+00
>>>>>>> 1 SNES Function norm 1.120717450009e-05
>>>>>>> 2 SNES Function norm 2.503394538611e-11
>>>>>>> 0 SNES Function norm 4.428377952757e+00
>>>>>>> ^CCtrl-C caught... cleaning up processes
>>>>>>>> Barry
>>>>>>>> On Oct 9, 2011, at 12:19 PM, Richard Katz wrote:
>>>>>>>>> Hi Barry,
>>>>>>>>> I have now run the code with
>>>>>>>>> configure_options = [
>>>>>>>>> '--download-mpich=1',
>>>>>>>>> '--with-cxx=0',
>>>>>>>>> '--with-fortran=0',
>>>>>>>>> 'PETSC_ARCH=debug_mpich',
>>>>>>>>> and
>>>>>>>>> The memory error goes away.
>>>>>>>>> The error in the calculated solution does not go away.
>>>>>>>>> Thanks,
>>>>>>>>> Rich
>>>>>>>>> On 9 Oct 2011, at 17:01, Barry Smith wrote:
>>>>>>>>>> Rich,
>>>>>>>>>> Could you do an identical run (to the valgrind run you made below) but using another PETSC_ARCH that uses --download-mpich
>>>>>>>>>> I am suspecting openmpi because it is a bad read of something INSIDE OpenMPI that was just outside the range of memory allocated BY OpenMPI, it is hard to see how PETSc could induce this particular memory problem.
>>>>>>>>>> Of course, it is also possible there are two bugs, one in OpenMPI and another in PETSc related to the DMDA.
>>>>>>>>>> Barry
>>>>>>>>>> On Oct 9, 2011, at 10:46 AM, Richard Katz wrote:
>>>>>>>>>>> Hi all,
>>>>>>>>>>> I'm beginning to wonder if there is a bug in the filling of ghost-points for 3-dimensional DMDAs under petsc-3.2. I am working on a finite-volume code that uses a DMDACreate3d() to create several DMDAs, all with a stencil width of two.
>>>>>>>>>>> * The 2-dimensional mode for the same code runs without problems in parallel.
>>>>>>>>>>> * The initial SNES solve converges well, with no seg-faults, but when there are processor bounds in the k-direction, the solution is clearly incorrect at/near the boundaries.
>>>>>>>>>>> * When I run the same code in serial, or in parallel but with no processor boundaries in the k-direction, it works without problems.
>>>>>>>>>>> * When I run the code with processor boundaries in the k-direction, but zeroing-out the bits of the stencil that are at stencil-radius of 2, the processor-boundary errors don't appear.
>>>>>>>>>>> * Extending the stencil width to 3 has no effect on the problem.
>>>>>>>>>>> * There does seem to be a memory-corruption problem, but I'm not sure where it comes from, because it appears very high in the stack. The following is valgrind output for a run with 2 processors. The processor boundary is in the k-direction. This memory error ONLY appears on the first SNES solve, but not on any of the following ones. Also, the memory error seems to be associated with OpenMPI; it doesn't occur when running with MPICH2
>>>>>>>>>>> [magmox:test]$ $PETSC_DIR/bin/petscmpiexec -valgrind -n 2 ../porbandsim -malloc off -nd 3 -alpha 2 -theta 45 -output_file test2
>>>>>>>>>>> ==4576== Invalid read of size 8
>>>>>>>>>>> ==4576== at 0x7FFFFFE00BAC: ???
>>>>>>>>>>> ==4576== by 0x101A34213: ompi_convertor_pack (in /usr/lib/libmpi.0.dylib)
>>>>>>>>>>> ==4576== by 0x10858909E: mca_pml_ob1_send_request_start_copy (in /usr/lib/openmpi/mca_pml_ob1.so)
>>>>>>>>>>> ==4576== by 0x1085840D2: mca_pml_ob1_isend (in /usr/lib/openmpi/mca_pml_ob1.so)
>>>>>>>>>>> ==4576== by 0x1085D11C3: ompi_coll_tuned_allreduce_intra_recursivedoubling (in /usr/lib/openmpi/mca_coll_tuned.so)
>>>>>>>>>>> ==4576== by 0x101A4419B: MPI_Allreduce (in /usr/lib/libmpi.0.dylib)
>>>>>>>>>>> ==4576== by 0x1001D3F3E: VecMDot_MPI (pvec2.c:20)
>>>>>>>>>>> ==4576== by 0x100204669: VecMDot (rvector.c:1144)
>>>>>>>>>>> ==4576== by 0x10097E28B: KSPGMRESClassicalGramSchmidtOrthogonalization (borthog2.c:66)
>>>>>>>>>>> ==4576== by 0x100975B33: GMREScycle (gmres.c:159)
>>>>>>>>>>> ==4576== by 0x10097656E: KSPSolve_GMRES (gmres.c:231)
>>>>>>>>>>> ==4576== by 0x1009A8606: KSPSolve (itfunc.c:423)
>>>>>>>>>>> ==4576== by 0x100A0271A: SNES_KSPSolve (snes.c:3396)
>>>>>>>>>>> ==4576== by 0x100A17F79: SNESSolve_LS (ls.c:190)
>>>>>>>>>>> ==4576== by 0x1009FB635: SNESSolve (snes.c:2676)
>>>>>>>>>>> ==4576== by 0x100008104: InitSolveElliptic (initialize.c:216)
>>>>>>>>>>> ==4576== by 0x10000538A: FormInitialCondition (initialize.c:31)
>>>>>>>>>>> ==4576== by 0x100001410: main (porbandsim.c:28)
>>>>>>>>>>> ==4576== Address 0x10289f778 is 0 bytes after a block of size 136 alloc'd
>>>>>>>>>>> ==4576== at 0x1010B05BF: malloc (vg_replace_malloc.c:266)
>>>>>>>>>>> ==4576== by 0x1085D0F98: ompi_coll_tuned_allreduce_intra_recursivedoubling (in /usr/lib/openmpi/mca_coll_tuned.so)
>>>>>>>>>>> ==4576==
>>>>>>>>>>> ==4577== Invalid read of size 8
>>>>>>>>>>> ==4577== at 0x7FFFFFE00BAC: ???
>>>>>>>>>>> ==4577== by 0x101A34213: ompi_convertor_pack (in /usr/lib/libmpi.0.dylib)
>>>>>>>>>>> ==4577== by 0x10858909E: mca_pml_ob1_send_request_start_copy (in /usr/lib/openmpi/mca_pml_ob1.so)
>>>>>>>>>>> ==4577== by 0x1085840D2: mca_pml_ob1_isend (in /usr/lib/openmpi/mca_pml_ob1.so)
>>>>>>>>>>> ==4577== by 0x1085D11C3: ompi_coll_tuned_allreduce_intra_recursivedoubling (in /usr/lib/openmpi/mca_coll_tuned.so)
>>>>>>>>>>> ==4577== by 0x101A4419B: MPI_Allreduce (in /usr/lib/libmpi.0.dylib)
>>>>>>>>>>> ==4577== by 0x1001D3F3E: VecMDot_MPI (pvec2.c:20)
>>>>>>>>>>> ==4577== by 0x100204669: VecMDot (rvector.c:1144)
>>>>>>>>>>> ==4577== by 0x10097E28B: KSPGMRESClassicalGramSchmidtOrthogonalization (borthog2.c:66)
>>>>>>>>>>> ==4577== by 0x100975B33: GMREScycle (gmres.c:159)
>>>>>>>>>>> ==4577== by 0x10097656E: KSPSolve_GMRES (gmres.c:231)
>>>>>>>>>>> ==4577== by 0x1009A8606: KSPSolve (itfunc.c:423)
>>>>>>>>>>> ==4577== by 0x100A0271A: SNES_KSPSolve (snes.c:3396)
>>>>>>>>>>> ==4577== by 0x100A17F79: SNESSolve_LS (ls.c:190)
>>>>>>>>>>> ==4577== by 0x1009FB635: SNESSolve (snes.c:2676)
>>>>>>>>>>> ==4577== by 0x100008104: InitSolveElliptic (initialize.c:216)
>>>>>>>>>>> ==4577== by 0x10000538A: FormInitialCondition (initialize.c:31)
>>>>>>>>>>> ==4577== by 0x100001410: main (porbandsim.c:28)
>>>>>>>>>>> ==4577== Address 0x10289f778 is 0 bytes after a block of size 136 alloc'd
>>>>>>>>>>> ==4577== at 0x1010B05BF: malloc (vg_replace_malloc.c:266)
>>>>>>>>>>> ==4577== by 0x1085D0F98: ompi_coll_tuned_allreduce_intra_recursivedoubling (in /usr/lib/openmpi/mca_coll_tuned.so)
>>>>>>>>>>> ==4577==
>>>>>>>>>>> Any suggestions about how to debug this? How well-tested are the parallel, 3D DMDA routines? Should I do some testing on a PETSc example code?
>>>>>>>>>>> I am running petsc-3.2 with
>>>>>>>>>>> changeset: 20338:fbd00cf1070e
>>>>>>>>>>> tag: tip
>>>>>>>>>>> parent: 20337:589176156279
>>>>>>>>>>> parent: 20336:7abcced43e69
>>>>>>>>>>> user: Barry Smith <bsmith at mcs.anl.gov>
>>>>>>>>>>> date: Tue Oct 04 16:45:00 2011 -0500
>>>>>>>>>>> summary: commit after merge
>>>>>>>>>>> and
>>>>>>>>>>> '--download-fftw=true',
>>>>>>>>>>> '--with-cxx=0',
>>>>>>>>>>> '--with-debugging=1',
>>>>>>>>>>> '--with-fortran=0',
>>>>>>>>>>> '--with-mpi-dir=/usr',
>>>>>>>>>>> 'PETSC_ARCH=debug',
>>>>>>>>>>> or
>>>>>>>>>>> '--download-blacs',
>>>>>>>>>>> '--download-mpich=yes',
>>>>>>>>>>> '--download-mumps=yes',
>>>>>>>>>>> '--download-parmetis',
>>>>>>>>>>> '--download-scalapack',
>>>>>>>>>>> '--with-cxx=0',
>>>>>>>>>>> '--with-debugging=0',
>>>>>>>>>>> 'PETSC_ARCH=optimize_mumps',
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Rich
>>>>>>>>> ________________________________
>>>>>>>>> Richard Foa Katz
>>>>>>>>> Dept Earth Sciences, Univ Oxford
>>>>>>>>> http://foalab.earth.ox.ac.uk
>>>>>>> Richard Foa Katz
>>>>> Richard Foa Katz
> Ethan Coon
> Post-Doctoral Researcher
> Applied Mathematics - T-5
> Los Alamos National Laboratory
> 505-665-8289
> http://www.ldeo.columbia.edu/~ecoon/
> <da-2d-in-3d-bugfix.txt>
