[petsc-dev] [petsc-maint #88993] Petsc with Cuda 4.0 and Multiple GPUs
Satish Balay petsc-maint at mcs.anl.gov
Mon Oct 3 22:18:00 CDT 2011
/home/wdn/Projects/Petsc/src/branches/master/petsc-dev/LINUX_GNU_OPTIMIZE_SERIAL_CUDA_40_LITE/include/txpetscgpu/include/csr_spmv_part_vector_gpu.h:23:44: error: thrust/detail/device/cuda/arch.h: No such file or directory
/usr/bin/ar: aijcusp.o: No such file or directory
This file is at ./thrust/detail/backend/cuda/arch.h in the
latest thrust.
Looks like txpetscgpu isn't updated to latest thrust.
[fixing 'device' -> 'backend' gives me different errors]
Satish
balay at bb30:~/petsc-dev/src/mat/impls/aij/seq/seqcusp>make
nvcc -g -arch=sm_13  -c --compiler-options="-Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3   -I/home/balay/petsc-dev/include -I/home/balay/petsc-dev/arch-cuda-double-tx/include -I/usr/local/cuda/include -I/home/balay/petsc-dev/arch-cuda-double-tx/include/txpetscgpu/include    -D__INSDIR__=src/mat/impls/aij/seq/seqcusp/" aijcusp.cu aijAssemble.cu
/home/balay/petsc-dev/arch-cuda-double-tx/include/txpetscgpu/include/csr_tri_solve_gpu_level_scheduler.h(312): error: name followed by "::" must be a class or namespace name
          detected during instantiation of "int csr_tri_solve_level_scheduler(const csr_matrix_data<index_type, value_type> *, index_type, index_type, index_type, const index_type *, const index_type *, const index_type *, value_type *) [with index_type=PetscInt, value_type=PetscScalar]"
aijcusp.cu(682): here
/home/balay/petsc-dev/arch-cuda-double-tx/include/txpetscgpu/include/csr_spmv_part_vector_gpu.h(275): error: name followed by "::" must be a class or namespace name
          detected during:
            instantiation of "bool csr_spmv_part_vector_gpu<assign_add_subtract,index_type,value_type>(const csr_matrix_data<index_type, value_type> &, index_type, index_type, index_type, index_type, index_type, const value_type *, value_type *, index_type, index_type, index_type, unsigned int) [with assign_add_subtract=operator_sub, index_type=PetscInt, value_type=PetscScalar]"
(412): here
            instantiation of "bool csr_spmv_sub_part_vector_gpu(const csr_matrix_data<index_type, value_type> &, index_type, index_type, index_type, index_type, index_type, const value_type *, value_type *, index_type, index_type, index_type, unsigned int) [with index_type=PetscInt, value_type=PetscScalar]"
/home/balay/petsc-dev/arch-cuda-double-tx/include/txpetscgpu/include/csr_tri_solve_gpu.h(111): here
            instantiation of "bool csr_tri_solve_gpu_hybrid(const csr_matrix_data<index_type, value_type> &, index_type *, uplo_enum, value_type *, value_type *, const csr_matrix_data<index_type, value_type> &, cuda_memory<value_type> &, cuda_memory<value_type> &, index_type, index_type, unsigned int) [with index_type=PetscInt, value_type=PetscScalar]"
/home/balay/petsc-dev/arch-cuda-double-tx/include/txpetscgpu/include/csr_tri_solve_gpu.h(173): here
            instantiation of "int csr_tri_solve_gpu_hybrid(const csr_matrix_data<index_type, value_type> *, index_type *, uplo_enum, value_type *, value_type *, const csr_matrix_data<index_type, value_type> *, value_type *, value_type *, index_type, index_type, unsigned int) [with index_type=PetscInt, value_type=PetscScalar]"
aijcusp.cu(815): here
<<<<< and more >>>>>>>>>
On Mon, 3 Oct 2011, Dave Nystrom wrote:
> Hi Barry,
> Just to be safe, I cloned the latest version of petsc-dev.  I then cloned
> cusp and thrust and installed them in /usr/local/cuda/include.  I then ran my
> petsc build script and the build failed.  I've included the petsc
> configure.log and make.log as well as the log from my makePetscDev script.
> Thanks,
> Dave
