[petsc-dev] [petsc-maint #88993] Petsc with Cuda 4.0 and Multiple GPUs
Barry Smith
bsmith at mcs.anl.gov
Sun Oct 2 20:38:56 CDT 2011
On Oct 2, 2011, at 6:39 PM, Dave Nystrom wrote:
> Thanks for the update. I don't believe I have gotten a run with good
> performance yet, either from C or Fortran. I wish there was an easy way for
> me to force use of only one of my gpus. I don't want to have to pull one of
> the gpus in order to see if that is complicating things with Cuda 4.0. I'll
> be eager to hear if you make any progress on figuring things out.
> Do you understand yet why the petsc ex2.c example is able to parse the
> "-cuda_show_devices" argument but ex2f.F does not?
Matt put the code in the wrong place in PETSc, that is all, no big existentialist reason. I will fix that.
Barry
> Thanks,
> Dave
> Barry Smith writes:
>> It is not doing the MatMult operation on the GPU and hence needs to move
>> the vectors back and forth for each operation (since MatMult is done on
>> the CPU with the vector while vector operations are done on the GPU) hence
>> the terrible performance.
>> Not sure why yet. It is copying the Mat down for me from C.
>> Barry
>> On Oct 2, 2011, at 4:18 PM, Dave Nystrom wrote:
>>> In case it might be useful, I have attached two log files of runs with the
>>> ex2f petsc example from src/ksp/ksp/examples/tutorials. One was run back in
>>> April with petsc-dev linked to Cuda 3.2. It shows excellent runtime
>>> performance. The other was run today with petsc-dev checked out of the
>>> mercurial repo yesterday morning and linked to Cuda 4.0. In addition to the
>>> differences in run time performance, I also do not see an entry for
>>> MatCUSPCopyTo in the profiling section. I'm not sure what the significance
>>> of that is. I do observe that the run time for PCApply is about the same for
>>> the two cases. I think I would expect that to be the case even if the
>>> problem were partitioned across two gpus. However, it does make me wonder if
>>> the absence of MatCUSPCopyTo in the profiling section of the Cuda 4.0 log
>>> file is an indication that the matrix was not actually copied to the gpu.
>>> I'm not sure yet how to check for that. Hope this might be useful.
>>> Thanks,
>>> Dave
>>> <ex2f_3200_3200_cuda_yes_cuda_3.2.log><ex2f_3200_3200_cuda_yes_cuda_4.0.log>
>>> Dave Nystrom writes:
>>>> Matthew Knepley writes:
>>>>> On Sat, Oct 1, 2011 at 11:26 PM, Dave Nystrom <Dave.Nystrom at tachyonlogic.com> wrote:
>>>>>> Barry Smith writes:
>>>>>>> On Oct 1, 2011, at 9:22 PM, Dave Nystrom wrote:
>>>>>>>> Hi Barry,
>>>>>>>> I've sent a couple more emails on this topic. What I am trying to do at the
>>>>>>>> moment is to figure out how to have a problem run on only one gpu if it will
>>>>>>>> fit in the memory of that gpu. Back in April when I had built petsc-dev with
>>>>>>>> Cuda 3.2, petsc would only use one gpu if you had multiple gpus on your
>>>>>>>> machine. In order to use multiple gpus for a problem, one had to use
>>>>>>>> multiple threads with a separate thread assigned to control each gpu. But
>>>>>>>> Cuda 4.0 has, I believe, made that transparent and under the hood. So now
>>>>>>>> when I run a small example problem such as
>>>>>>>> src/ksp/ksp/examples/tutorials/ex2f.F with an 800x800 problem, it gets
>>>>>>>> partitioned to run on both of the gpus in my machine. The result is a very
>>>>>>>> large performance hit because of communication back and forth from one gpu to
>>>>>>>> the other via the cpu.
>>>>>>> How do you know there is lots of communication from the GPU to the CPU? In
>>>>>>> the -log_summary? Nope because PETSc does not manage anything like that
>>>>>>> (that is one CPU process using both GPUs).
>>>>>> What I believe is that it is being managed by Cuda 4.0, not by petsc.
>>>>>>>> So this problem with a 3200x3200 grid runs 5x slower
>>>>>>>> now than it did with Cuda 3.2. I believe if one is programming down at the
>>>>>>>> cuda level, it is possible to have a smaller problem run on only one gpu so
>>>>>>>> that there is communication only between the cpu and gpu and only at the
>>>>>>>> start and end of the calculation.
>>>>>>>> To me, it seems like what is needed is a petsc option to specify the number
>>>>>>>> of gpus to run on that can somehow get passed down to the cuda level through
>>>>>>>> cusp and thrust. I fear that the short term solution is going to have to be
>>>>>>>> for me to pull one of the gpus out of my desktop system but it would be nice
>>>>>>>> if there was a way to tell petsc and friends to just use one gpu when I want
>>>>>>>> it to.
>>>>>>>> If necessary, I can send a couple of log files to demonstrate what I am
>>>>>>>> trying to describe regarding the performance hit.
>>>>>>> I am not convinced that the poor performance you are getting now has
>>>>>>> anything to do with using both GPUs. Please run a PETSc program with the
>>>>>>> command -cuda_show_devices
>>>>>> I ran the following command:
>>>>>> ex2f -m 8 -n 8 -ksp_type cg -pc_type jacobi -log_summary -cuda_show_devices
>>>>>> -mat_type aijcusp -vec_type cusp -options_left
>>>>>> The result was a report that there was one option left, that being
>>>>>> -cuda_show_devices. I am using a copy of petsc-dev that I cloned and built
>>>>>> this morning.
>>>>> What do you have at src/sys/object/pinit.c:825? You should see the code
>>>>> that processes this option. You should be able to break there in the
>>>>> debugger and see what happens. This sounds again like you are not
>>>>> processing options correctly.
>>>> Hi Matt,
>>>> I'll take a look at that in a bit and see if I can figure out what is going
>>>> on. I do see the code that you mention that processes the arguments that
>>>> Barry mentioned. In terms of processing options correctly, at least in this
>>>> case I am actually running one of the petsc examples rather than my own
>>>> code. And it seems to correctly process the other command line arguments.
>>>> Anyway, I'll write more after I have had a chance to investigate more.
>>>> Thanks,
>>>> Dave
>>>>> Matt
>>>>>>> What are the choices? You can then pick one of them and run with
>>>>>> -cuda_set_device integer
>>>>>> The -cuda_set_device option does not appear to be recognized either, even
>>>>>> if I choose an integer like 0.
>>>>>>> Does this change things?
>>>>>> I suspect it would change things if I could get it to work.
>>>>>> Thanks,
>>>>>> Dave
>>>>>>> Barry
>>>>>>>> Thanks,
>>>>>>>> Dave
>>>>>>>> Barry Smith writes:
>>>>>>>>> Dave,
>>>>>>>>> We have no mechanism in the PETSc code for a PETSc single CPU process to
>>>>>>>>> use two GPUs at the same time. However you could have two MPI processes
>>>>>>>>> each using their own GPU.
>>>>>>>>> The one tricky part is you need to make sure each MPI process uses a
>>>>>>>>> different GPU. We currently do not have a mechanism to do this assignment
>>>>>>>>> automatically. I think it can be done with cudaSetDevice(). But I don't
>>>>>>>>> know the details, sending this to petsc-dev at mcs.anl.gov where more people
>>>>>>>>> may know.
>>>>>>>>> PETSc-folks,
>>>>>>>>> We need a way to have this setup automatically.
>>>>>>>>> Barry
>>>>>>>>> On Oct 1, 2011, at 5:43 PM, Dave Nystrom wrote:
>>>>>>>>>> I'm running petsc on a machine with Cuda 4.0 and 2 gpus. This is a desktop
>>>>>>>>>> machine with a single processor. I know that Cuda 4.0 has support for
>>>>>>>>>> running on multiple gpus but don't know if petsc uses that. But suppose I
>>>>>>>>>> have a problem that will fit in the memory for a single gpu. Will petsc run
>>>>>>>>>> the problem on a single gpu or does it split it between the 2 gpus and incur
>>>>>>>>>> the communication overhead of copying data between the two gpus?
>>>>>>>>>> Thanks,
>>>>>>>>>> Dave
>>>>> What most experimenters take for granted before they begin their experiments
>>>>> is infinitely more interesting than any results to which their experiments
>>>>> lead.
>>>>> -- Norbert Wiener
