[petsc-dev] [petsc-maint #88993] Petsc with Cuda 4.0 and Multiple GPUs
Barry Smith
bsmith at mcs.anl.gov
Sat Oct 1 21:30:32 CDT 2011
On Oct 1, 2011, at 9:22 PM, Dave Nystrom wrote:
> Hi Barry,
> I've sent a couple more emails on this topic. What I am trying to do at the
> moment is to figure out how to have a problem run on only one gpu if it will
> fit in the memory of that gpu. Back in April when I had built petsc-dev with
> Cuda 3.2, petsc would only use one gpu if you had multiple gpus on your
> machine. In order to use multiple gpus for a problem, one had to use
> multiple threads with a separate thread assigned to control each gpu. But
> Cuda 4.0 has, I believe, made that transparent and under the hood. So now
> when I run a small example problem such as
> src/ksp/ksp/examples/tutorials/ex2f.F with an 800x800 problem, it gets
> partitioned to run on both of the gpus in my machine. The result is a very
> large performance hit because of communication back and forth from one gpu to
> the other via the cpu.
How do you know there is lots of communication from the GPU to the CPU? In the -log_summary? Nope because PETSc does not manage anything like that (that is one CPU process using both GPUs).
> So this problem with a 3200x3200 grid runs 5x slower
> now than it did with Cuda 3.2. I believe if one is programming down at the
> cuda level, it is possible to have a smaller problem run on only one gpu so
> that there is communication only between the cpu and gpu and only at the
> start and end of the calculation.
> To me, it seems like what is needed is a petsc option to specify the number
> of gpus to run on that can somehow get passed down to the cuda level through
> cusp and thrust. I fear that the short term solution is going to have to be
> for me to pull one of the gpus out of my desktop system but it would be nice
> if there was a way to tell petsc and friends to just use one gpu when I want
> it to.
> If necessary, I can send a couple of log files to demonstrate what I am
> trying to describe regarding the performance hit.
I am not convinced that the poor performance you are getting now has anything to do with using both GPUs. Please run
a PETSc program with the command -cuda_show_devices
What are the choices? You can then pick one of them and run with -cuda_set_device integer
Does this change things?
Barry
> Thanks,
> Dave
> Barry Smith writes:
>> Dave,
>> We have no mechanism in the PETSc code for a PETSc single CPU process to
>> use two GPUs at the same time. However you could have two MPI processes
>> each using their own GPU.
>> The one tricky part is you need to make sure each MPI process uses a
>> different GPU. We currently do not have a mechanism to do this assignment
>> automatically. I think it can be done with cudaSetDevice(). But I don't
>> know the details, sending this to petsc-dev at mcs.anl.gov where more people
>> may know.
>> PETSc-folks,
>> We need a way to have this setup automatically.
>> Barry
>> On Oct 1, 2011, at 5:43 PM, Dave Nystrom wrote:
>>> I'm running petsc on a machine with Cuda 4.0 and 2 gpus. This is a desktop
>>> machine with a single processor. I know that Cuda 4.0 has support for
>>> running on multiple gpus but don't know if petsc uses that. But suppose I
>>> have a problem that will fit in the memory for a single gpu. Will petsc run
>>> the problem on a single gpu or does it split it between the 2 gpus and incur
>>> the communication overhead of copying data between the two gpus?
>>> Thanks,
>>> Dave
